    Mechanical hum: power transformer
    2turbos
    Post by 2turbos on Wed Oct 18, 2017 4:55 pm
    I have a hum problem with my Stereo 70. It's mechanical, no detectable  hum in the signal on the outputs.
    I assume it has to do with the way the transformer mounts to the chassis. If I put a heavy weight on it then the buzz stops.
    Any way to isolate the transformer mechanically?
    Last edited by 2turbos on Wed Oct 18, 2017 4:56 pm; edited 1 time in total (Reason for editing : grammar)
    Re: Mechanical hum: power transformer
    Post by Bob Latino on Wed Oct 18, 2017 7:51 pm
    2turbos wrote:I have a hum problem with my Stereo 70. It's mechanical, no detectable  hum in the signal on the outputs.
    Get FOUR 00 (double zero) flat neoprene plumbing washers and place them between the transformer and the top of the chassis. These will absorb most of the mechanical vibrations of the power transformer. Don't overtighten on top of these washers or you will flatten them out and they will loose their ability to absorb the vibrations.
    All VTA amps have "isolation washers" between the power transformers and the chassis.
    2turbos
    Post by 2turbos on Wed Oct 18, 2017 8:07 pm
    Thanks Bob. I was thinking along those same lines but wanted to check with forum members to see what they had done.
    Sounds like this problem already has a solution.
    PeterCapo
    Post by PeterCapo on Thu Oct 19, 2017 9:39 pm
    Dynakitparts offers an isolation kit for the power transformer to reduce vibration http://www.dynakitparts.com/dynakit-products/hardware/POWER-TRANSFORMER-ISOLATION-MOUNTS
    There might also be some DC offset on the AC mains, and I have read posts by others who, having eliminated the DC component, had a more peaceful power transformer:
    https://emotiva.com/product/cmx-2/
    and
    http://avahifi.com/products/accessories/humdinger-dc-line-blocker
    You might also try snugging the bolts holding the transformer cover on.
      Current date/time is Tue Jan 23, 2018 5:58 am
