    Zobel Network
    Pillo69
    Zobel Network
    Post by Pillo69 on Wed Oct 18, 2017 6:50 pm
    Hi.
    Does anyone use a zobel at the exit of the ST70?
    What would be the correct CR values?
    Here a calculator that needs values of the speakers, although there are amplifiers that include it from the factory.
    http://diyaudioprojects.com/Technical/Speaker-Zobel/
    Thank you.
    Re: Zobel Network
    Post by Peter W. on Fri Oct 20, 2017 1:02 pm
    Pillo69 wrote:Hi.
    Thank you.
    Where:
    Re is the DC Resistance of the driver [ohms]          Can be taken with a standard VOM.
    Le is the Voice coil Inductance of the driver [H]      Needs an LCR meter, or specification from the driver OEM.
    Rz is the calculated Zobel resistor [ohms] and        Will calculate when the values above are input.
    Cz is the calculated Zobel capacitor [F].                 Will calculate when the values above are input.
    Now, VC inductance is usually tiny - use one (1) mH and you should be within the ballpark. The typical driver at rest (resistance) is usually, 4, 6, or 8 oms. Try dropping those values into the calculation and see if they make sense. Then, drop an L-pad vs. resistor into the network and you have some additional control.
    Yes, I keep an LCR meter - I hadn't thought about this use, however. As a side-bar, I am working with another member here to clone the Dynaco A40 crossover to back-fill earlier resistor/cap crossovers in A25-on-up speakers. Using the OEM values I back-calculated to a crossover point of about 1,700 HZ - and that system uses a small air-core choke of about 0.75mH, and an 8.2uF NP cap with an 8-ohm L-pad. I will measure the VC inductance of the tweeter - that will give me the exact crossover point. But, you get the idea - small changes = significant effects.
    If this effort bears fruit - I will 'show my work' and source the parts for those here. My goal is to make it sufficiently simple that it is the work of a couple of hours if even that.
      Current date/time is Tue Jan 23, 2018 5:57 am
