    Dynaco st 70 series ll and pas 3 series ll
    Sergio
    Sergio
    Dynaco st 70 series ll and pas 3 series ll Empty Dynaco st 70 series ll and pas 3 series ll
    Post by Sergio Tue Dec 26, 2017 7:29 am
    Dear friends,
    I have the opportunity to buy a Dynaco st 70 series ll and pas 3 series ll
    The price would be 800 dollars.
    Could you recommend me if it's worth your purchase.
    I do not see references of the quality of these devices.
    I thank you very much for your help
    Dynaco st 70 series ll and pas 3 series ll Empty Re: Dynaco st 70 series ll and pas 3 series ll
    Post by peterh Tue Dec 26, 2017 9:27 am
    Sergio wrote:Dear friends,
    Y E S ! !
    Post by Bob Latino Tue Dec 26, 2017 11:36 am
    The only problem I see with the purchase of either or both units is that AFAIK there are no boards available for either unit should you need to replace a board ? There is no aftermarket support for either the PAS-3 or ST-70 Series II. The PAS-3 series II was a transitional model from the early '90's put out by Panor. Later in the 1990's, Panor came out with the PAS-4 which is a very well made unit and better sounding than any PAS-3. A few years ago I had the opportunity to work on a PAS-4 for a local customer. Well made and a good sounding preamp for its day. The PAS-3 Series II had six 12AX7 tubes rather than four 12AX7 tubes like the original PAS-2/3. PAS-3 Series II schematic below ..
    Dynaco st 70 series ll and pas 3 series ll Dynaco_PAS3_Series_II_schematic
    Post by j beede Tue Dec 26, 2017 1:30 pm
    The circuitry can be repaired/updated. There is not too much that can be done about the cosmetics. If they are original, complete, stock, and look very good I would probably be a buyer.
    DynakitParts
    DynakitParts
    Dynaco st 70 series ll and pas 3 series ll Empty PAS 3 Series II
    Post by DynakitParts Tue Dec 26, 2017 7:22 pm
    Hi Guys,
    Merry Christmas....
    Finding a replacement circuit board mounted power transformer for this Series II preamp will be very difficult and this appears to be a common problem with this specific unit.
    Just my two cents on this....I agree with Bob that the PAS 4 is the more desirable unit.
    Regards,
    Kevin
      Current date/time is Fri Apr 19, 2024 5:10 am
