    6h30pi tube
    scottlowe76
    6h30pi tube
    Post by scottlowe76 on Sat Jan 06, 2018 3:00 pm
    another silly question . can a 6H30PI be used in place of a 12au7 ?thx for your patience !
    Re: 6h30pi tube
    Post by Bob Latino on Sat Jan 06, 2018 4:17 pm
    scottlowe76 wrote:another silly question . can a 6H30PI be used in place of a 12au7 ?thx for your patience !
    To my knowledge there is no direct substitute for the 6H30 tube. The pin out is also different than a 12AU7. The 6H30 also sucks much more filament current than a 12AU7.
    erhard-audio
    Re: 6h30pi tube
    Post by erhard-audio on Sat Jan 06, 2018 9:48 pm
    a good way for 'newbies' to learn about different tubes and their compatibility with other tube models, enter the tube model into your search engine and call up the data sheet for that tube. It will tell you everything you need to know, including the pinout and filament current. You may not necessarily understand all the numbers and other data, but spend some time comparing the data sheets of two different tubes, and some things and numbers should start to make sense. study
    Re: 6h30pi tube
      Current date/time is Tue Sep 25, 2018 9:59 am
