Roy wrote:Thanks Peter and Cletus - goes a ways towards me understanding things!
As for the tube rectifier - I see too many guitars in your profile pic Cletus ^_^ suspect at some point you will be hooking one up to the 120 and then that sag is something you would want and feel while playing adding that depth to the feel you get playing but when I play back something beefy out of my collection I like the amp to rumble without a grumble so a Weber WS1 and the TDR board is on the list
The system in a nutshell:
The guitars and amplifier shown have always been my dream equipment (Fender Jaguar, Fender Starcaster and Fender Silverface 1974 Twin Reverb amp - Blackface modified).
There is a single octave Oxygen 25 Midi keyboard too.
The recording/playback/mastering console is a mix-match of stuff centered around Band in a Box, Cakewalk and the GNX3 Guitar Workstation.
My go-to live/recording mics are the Sure SM-57 and the Audio Technica AT-3525 studio mic.
After the vocal mic there is usually a TC-Helicon HarmonyG-XT Vocal Processor to sweeten things up a bit and create harmonies when needed.
The studio near-field monitors are the very affordable, but nice (IMHO) Edifier powered R1280T.
Studio headphone monitors are AKG K44s.
Mixing board (the gateway to the recording system) is Behringer Xenix 1202FX
Optiplex 755 PC maxed-out with memory and hard drives and a M-Audio Audiophile Sound Card running Windows 7.
Preamp intervention in all that is my own design 12AX7 build / solid-state tone stack with a Pass Labs J-FET buffer.
The output from the Preamp can indeed be readily routed via an A/B selector to the ST-120 / A7s or the Edifiers.
Quite a versatile little home recording rig, if I do say so myself.
Of course Rome was not built in a day, so this has been a labor of love (and sometimes frustration) spanning many years!
BTW the EQ pictured was never in-circuit but used only for the Spec-analyser display with a calibrated Leader Mic and a home-brew pink noise generator (it is now out the door ....too many nice pc-based, FFT spec analyzers out there).
