    SP-14 to Class D amplifier
    Fitero
    Post by Fitero on Thu Feb 22, 2018 7:06 pm
    I've had this preamp connected to several solid state amplifiers since building it a few years ago, but this week I tried something new for me;
    I hooked it to a balanced input only, class D amplifier. It was not happy! The speakers give out a fairly loud, high pitched squeal. I tried several wiring and grounding variations to no avail. OK. Next I tried placing a buffer that I made (Kuartlotron Buffer) between the preamp and the amp. This brought the squeal amplitude down quite a bit, but it's still there.
    The music sounds marvelous, despite the squeal, so I would like to resolve the issue.
    I've searched for appropriate buffers, but I don't know enough to pick the right one. I'd be grateful for any suggestions.
    Thank you.
    pigface
    Re: SP-14 to Class D amplifier
    Post by pigface on Thu Feb 22, 2018 9:18 pm
    I had  a similar experiance . When I built my SP14  I tried using it with  my Krell  FPB
    (Class A) through the balanced  inputs , nightmare !  I tried  different cables  then
    RCA to XLR jumper adapters . Both resulted in only obnoxious very loud
    noises , buzzing and screeching , from the speakers for a few seconds and then the amp
    shutting down and going into protection mode !
          I then tried a generic electronic balanced to unbalanced device  that was a only little
    better , at least I could hear music through  one speaker now then the other , one at a time
    and “less” hum and screeching  .  I think they all were creating a very bad ground loop
    resulting in the noise ?
         I finally had Roy build me a balanced to unbalanced adapter box that uses lundahl
    LL1527 ?  transformers in it .   Finally it works right , and sounds incredible , perfectly
    quiet . I couldn’t be happier . It sounds so much better than with my old solid state Preamp  .
         I don’t know  if this would work with a class D amp for you or not ?  Give Roy a
    shout  and ask him .
    Fitero
    Post by Fitero on Thu Feb 22, 2018 10:38 pm
    Thank you for the suggestion PF!!
    That rings true, as I've seen a similar scenario in a couple of Don Sachs' versions when he has used XLR inputs.
    I'll bug Roy now.
    Post by Peter W. on Fri Feb 23, 2018 10:02 am
    Fitero wrote:Thank you for the suggestion PF!!
    I'll bug Roy now.
    Back in the day, when solid-state was 'new' a number of amplifier manufacturers used interstage transformers to prevent just what you are describing. So, the suggestion is both apt and effective.
    Post by Roy on Fri Feb 23, 2018 10:17 am
    Could it be your Dynaco pre amp is oscillating? Or perhaps that Class D power stage..
    Fitero
    Post by Fitero on Fri Feb 23, 2018 8:30 pm
    Interesting. There are cheap solutions available at the local Guitar Centers apparently, but I hate to waste money. A pair of good isolation transformers isn't to expensive if it takes away the noise.
    It's a VTA SP-14 preamp. The JBL/Crown amp has no trouble connected directly via XLR cable to my Logitech Transporter. I'll know soon enough!
      Current date/time is Sat Jun 23, 2018 1:24 pm
