    Norman Koren Spiced PAS schematics difference.
    starwatcher
    Post by starwatcher on Mon Mar 05, 2018 2:09 am
    I was ready to buy Norman Koren PAS boards from classic valves but the line board is sold-out.
    I can manage a point to point circuit but i notice the C out capacitor is 3.3uf on Koren website and .47uf on the part list of Classic valves.
    I also see there's few different resistor so i can use one or the other schematics with the same results?
    Thanks.
    WLT
    N Koren question
    Post by WLT on Fri Mar 09, 2018 12:12 pm
    I am building a phono preamp using the NK board. Not to be completed any time soon but it will get done.
    The question about C out. The larger cap is preferred if you have a long length of interconnect cable to the amp or are using low input impedance amps (solid state). If you use tube amps with large input grid resistors (475K +/-) the smaller caps are just fine. That cap, the cables and the input resistance set up a filter that can effect the low frequency of the system. You could always try each one and see what if any difference there is.
      Current date/time is Mon Sep 24, 2018 4:32 am
