    Is my rectifier tube bad?
    MV213
    Post by MV213 on Sat Mar 24, 2018 4:27 pm
    I just finished my ST-120 this morning. Just before lunch I got the first 6550 biased with no problems following the initial startup instructions from Bob. I then shut the amp down to have lunch. Starting back up, I now have no bias and no B+. I still have 430 vac at the rectifier tube. Seems likely to be the rectifier tube but I wanted to run it by the experts here. I think I’ll switch to a Weber copper cap if that’s the issue, I do have the TDR.
    Thanks for any help!
    J.P. Mears
    Dallas, OR—the OTHER Big D
    MV213
    Re: Is my rectifier tube bad?
    Post by MV213 on Sat Mar 24, 2018 7:36 pm
    Well, I was anxious to try the amp out so I bypassed the rectifier tube with a couple of 1N4007 diodes. Success! My amp biased up beautifully and fired up and sounds great! I have some modifications to do, so no pictures yet. I’m glad I opted for the TDR even though I planned to use a tube rectifier.
    A quick conversation with Bob prompted me to look at my line voltage which is kind of high, almost 124 VAC. I will be picking up a variac. I’ve also ordered a new rectifier tube of a different brand and will do the diode backup mod on it.
    Post by j beede on Sun Mar 25, 2018 12:27 am
    Well done. 1n4007 diodes are your friend and every DIY tube audio fan should keep a supply on hand. Also, if you don't already have them, add a couple 22uF, 450V electrolytics to your tool kit. These are the easiest way to confirm/bypass a bad segment in a quad cap.
    Post by Bob Latino on Sun Mar 25, 2018 9:57 am
    MV213 wrote:A quick conversation with Bob prompted me to look at my line voltage which is kind of high, almost 124 VAC.  I will be picking up a variac.   I’ve also ordered a new rectifier tube of a different brand and will do the diode backup mod on it.
    On the back of the parts list sheet on every VTA amp kit is a warning about running your VTA amp at voltages of 122 VAC or higher. Your addition of diodes in place of a rectifier tube will make the B+ DC voltage even higher than with a tube rectifier. My advice is to not run the amp until your variac arrives.
    MV213
    Post by MV213 on Sun Mar 25, 2018 11:58 am
    Thanks Bob! I should have it soon. In the meantime I’ll work on my mods. Thanks again for your help.
    bluemeanies
    bluemeanies
    Post by bluemeanies on Sun Mar 25, 2018 2:14 pm
    Thank God I purchase a Variac!
    My in house voltage level varies as low as 117 and as high as 125 on a daily basis. Since the addition of the Variac it takes the guesswork out of the equation and knowing my m125's are operating safely.
    A worthwhile investment.
    MV213
    Post by MV213 on Sun Mar 25, 2018 11:59 pm
    I didn’t realize my voltage was so high. My variac is on the way. Mods continue, hopefully will wrap them up in a day or so.
      Current date/time is Sat Mar 23, 2019 1:39 pm
