+9
chefothefuture
Dogstar
Dale Stevens
kevinmi
CletusB
nmchiefsfan
13 posters
A question of tubeage ref the VTA ST-120 drivers
deepee99- Posts : 2244
Gentle people, a simple question about the ST-120 drivers. There are three of them. I have been told alternatively that the two on the side matter the most, OTOH that the one in the centre makes the larger difference in SQ. Please, no sound-staging or other imaginary BS. If you had a king's ransom, which hole(s) would you fill?
nmchiefsfan- Posts : 77
The center tube is the will impact the sound quality the most.
CletusB- Posts : 234
Center tube! ...that's the voltage amplifier (like a pre-amp if you will)! the other two are simply the phase-inverters.
corndog71- Posts : 840
deepee99 wrote:Gentle people, a simple question about the ST-120 drivers. There are three of them. I have been told alternatively that the two on the side matter the most, OTOH that the one in the centre makes the larger difference in SQ. Please, no sound-staging or other imaginary BS. If you had a king's ransom, which hole(s) would you fill?
Sound stages are imaginary? That’s news to me.
Corndog, I was being a tad facetious.corndog71 wrote:deepee99 wrote:Gentle people, a simple question about the ST-120 drivers. There are three of them. I have been told alternatively that the two on the side matter the most, OTOH that the one in the centre makes the larger difference in SQ. Please, no sound-staging or other imaginary BS. If you had a king's ransom, which hole(s) would you fill?
kevinmi- Posts : 88
I'd stick with vintage tubes. I'm using RCA clear tops on the sides with a vintage Tung-Sol in the center. I had a RCA clear top in the center for a while, but the Tung-Sol has a bit more bass.
Dale Stevens- Posts : 201
12BH7AEH (EH)
Dale, I should have specified I've got the 8-holer driver board.Dale Stevens wrote:12BH7AEH (EH)
Not a huge fan of EH tubes but maybe they have improved since I tried them.
kevinmi- Posts : 88
Just bought a pair of vintage Sylvania 12BH7 tubes to try out. Should be here in a week.
kevinmi- Posts : 88
For octal tubes, I'm running 1940's vintage Ken-Rad 6sn7's in my preamp(Cary SLP-98P) with great results.deepee99 wrote:Dale, I should have specified I've got the 8-holer driver board.Dale Stevens wrote:12BH7AEH (EH)
chefothefuture- Posts : 28
Hi all- Noob to the forum but not to the Dyna/VTA ST120. Just built two. In one, using KT120s for outputs, I have three Northern Electric 6SN7s.
In the other, with new production Genalex KT88s, the outer phase splitters are EH 6SN7 gold pin, and a Psvane UK 6SN7.
Both amps sound great to me though OCD sets in and I await a Treasure CV181 to try...
I also installed a VTA driver board in my Dyna ST70. For that I used Psvane UK 6SN7s for the splitters and an EH 6SN7 Gold Pin for the center. Nice too but certainly not as full as the VTA ST120s.
Dogstar- Posts : 361
For the most part as much as everyone would like to hear phenomally improved acoustic characteristics when a set of kings ransom priced magic tubes are installed at best there are only subtle differences that can at best be described as better based only on personal preference. Sure there might be a defective tube that does make the sound significantly different (and bad). But once the tubes are installed and biased correctly and listened to for a while there is no way someone is going to be able to say they distinctly heard a tube they listened to hours ago sounds better than the tube they are currenltly using. Of course I know I'm being blasphemous and a bad man (inser vulgarity here) but if someone says that they are full of themselves.
Dogstar wrote:For the most part as much as everyone would like to hear phenomally improved acoustic characteristics when a set of kings ransom priced magic tubes are installed at best there are only subtle differences that can at best be described as better based only on personal preference. Sure there might be a defective tube that does make the sound significantly different (and bad). But once the tubes are installed and biased correctly and listened to for a while there is no way someone is going to be able to say they distinctly heard a tube they listened to hours ago sounds better than the tube they are currenltly using. Of course I know I'm being blasphemous and a bad man (inser vulgarity here) but if someone says that they are full of themselves.
Hahahaha! You could be right, though I did notice a subtle difference here and there. The biggest difference came when I went from a GZ34 rectifier to a GZ37, but that's a different topic all together.
Peter W.- Posts : 1351
Let's get down to those proverbial brass tacks:
a) Generally, tubes, like democracy, are a wretched way to make music, or run a government. Except for everything else.
b) Given that all tubes are bad, it may be stated with confidence that all *some* pre-blight tube will be better than *all* present production tubes.
c) As to "big" or "small" driver tubes, de gustibus et coloribus non est disputandum. Jut mind the filament load, if applicable. For instance, a very good (and they are few) pair of Sylvania 7199 tubes will blow the socks off of any present-production 6SN7 array. ->OPINION<-
heeheehee
heeheehee
sKiZo- Posts : 1530
kevinmi wrote:Dale Stevens wrote:12BH7AEH (EH)
All Sylvania here now ... 12BH7's (circa '62) and an early '50's VT231 center.
Then again, check back next week ...
PS - I'd mention the exemplary sound stage with this set if there was such a thing.
Peter W. wrote:Let's get down to those proverbial brass tacks:
heeheehee
Peter, glad you qualified that with "present production." Late 1940s Sylvania VT231/6SN7s are pretty hard to beat if you're running an 8-holer. Andy Bowman says the 7199s are crap.
[quote="deepee99"]
The varieties and range-of-options using pre-blight tubes is considerable, and 7199s are quite problematic as these things go. So, yes. That "Present Production" is an important distinction.
peterh- Posts : 1832
One can always mount the 7199 in a noval-to-octal converter :-)
Quite true, but I thought the purpose of the VTA board was to get away from the 7199s...
I realized my previous comment was in error. Forget the topic referred to all driver types. Many apologies.
heeheehee
Given the hoopla and superfluous hyperbole surrounding many tubes I wouldn’t rule out placebo effect. Similar to the ongoing debate as to whether vinyl sounds better than CD...
Perhaps it mostly boils down to what the individual perceives and enjoys.
[quote="chefothefuture"]
That would be a giant BINGO!!
Yep. I am always informed by "The Billionaires' Vinegar" when it comes to tubeage. A great read, BTW.chefothefuture wrote:Peter W. wrote:Let's get down to those proverbial brass tacks:
heeheehee
chefothefuture wrote:Quite true, but I thought the purpose of the VTA board was to get away from the 7199s...
Yes > Why use a driver board using driver tubes (7199) that are not made anymore ? The price of the remaining crop of 7199's keeps getting higher and higher each year. Right now the average price of an NOS 7199 is maybe $35 or $40. Also there is no other driver tube that you can substitute for a 7199 with a direct plug in ? Sure - You can use a 6GH8A as a replacement driver tube with a suitable adapter but the adapters are $10 and up per tube.
10-E-C- Posts : 267
Bob Latino wrote:chefothefuture wrote:Quite true, but I thought the purpose of the VTA board was to get away from the 7199s...
I found two RCA 7199 at an estate sale for 1 dollar, mint old stock.
Since the original question was about preferred driver tubes in a VTA ST120, will 7199s even work in one?
