    Wiring question
    WireNut
    WireNut
    Re: Wiring question
    Post by WireNut on Sun Apr 08, 2018 5:58 pm
    I also noticed that Bob reinvented the Dynaco wheel with all of the changes he did- way to break the mold Bob! (see page with differences between the old amp and his)
    Re: Wiring question
    Post by deepee99 on Sun Apr 08, 2018 6:21 pm
    Wirenut,
    Sure hope you post some pix of your build as it progresses.
    WireNut
    WireNut
    Re: Wiring question
    Post by WireNut on Mon Apr 09, 2018 1:05 pm
    Hey guys, I do have a wiring question, I have a Hakko FM-202 soldering station & usually set it at °600 for making cables, but know that some traces may fry with that heat. What do you set your irons for on your Dynaco projects?
    Re: Wiring question
    Post by deepee99 on Mon Apr 09, 2018 1:11 pm
    IMHO, you risk more damage to the traces with low heat and longer contact time with the soldering iron. Get 'er hot, do 'er fast.
    cci1492
    cci1492
    Re: Wiring question
    Post by cci1492 on Mon Apr 09, 2018 3:38 pm
    650°F
    chefothefuture
    Re: Wiring question
    Post by chefothefuture on Mon Apr 09, 2018 4:30 pm
    I have a Hakko 888D which I have not been able to change from the pre-set 750F.
    Haven't had a problem with damage to the boards or components. The only thing I have had trouble with (and this has been with different irons) is getting the solder to properly flow in the smaller through holes. Not sure if it's a flux or solder quality issue, or bad technique.
    WireNut
    WireNut
    Re: Wiring question
    Post by WireNut on Mon Apr 09, 2018 5:35 pm
    There are really good videos on Youtube on how to solder correctly, check a couple of them out.
    chefothefuture
    Re: Wiring question
    Post by chefothefuture on Tue Apr 10, 2018 11:25 pm
    WireNut wrote:There are really good videos on Youtube on how to solder correctly, check a couple of them out.
    I have. Still have trouble.
    WireNut
    WireNut
    Re: Wiring question
    Post by WireNut on Wed Apr 11, 2018 9:21 am
    Maybe you are using the wrong tip for the job, the thin pointed ones do not get quite the same results, I like too use a tip that is not pointed but a small spade shape, for big jobs I will use a larger spade or a knife shaped tip. Maybe some other guys can weigh in to help the chief?
    chefothefuture
    Re: Wiring question
    Post by chefothefuture on Wed Apr 11, 2018 10:39 am
    WireNut wrote:Maybe you are using the wrong tip for the job, the thin pointed ones do not get quite the same results, I like too use a tip that is not pointed but a small spade shape, for big jobs I will use a larger spade or a knife shaped tip. Maybe some other guys can weigh in to help the chief?
    I also might be using too much heat and perhaps parts need to be cleaned (just saw that in a video) prior to installing.
    cci1492
    cci1492
    Re: Wiring question
    Post by cci1492 on Wed Apr 11, 2018 11:10 am
    practice is everything
    chefothefuture
    Re: Wiring question
    Post by chefothefuture on Thu Apr 12, 2018 9:23 pm
    Or just saying to heck with it and spend the extra $40 on a ready made board. When you think of the value in hours it takes to build the board,including troubleshooting, $40 is a great deal. The hand wiring of the rest of the amp is the fun part (for me anyway).
    Re: Wiring question
    Post by deepee99 on Thu Apr 12, 2018 10:17 pm
    chefothefuture wrote:Or just saying to heck with it and spend the extra $40 on a ready made board. When you think of the value in hours it takes to build the board,including troubleshooting, $40 is a great deal. The hand wiring of the rest of the amp is the fun part (for me anyway).
    Yep.
    Re: Wiring question
      Current date/time is Sat Mar 23, 2019 1:38 pm
