Hi, first time poster long time lurker. I purchased some used iron on eBay for my next project. Seems there is a problem with the
with the wire colors fading out on the Power Transformer. I removed the bells, no help. Used an Ohm meter and got most taken care of.
The only problem are the two short leads, B+ and the Ground CT. One wire is Red and white and reads 28.7ohms across the Red high voltage
lead, the other is Blue and white and reads 24.7ohms. I just hope someone has a PT laying around and can check the ohm readings. It must
be out of the chassis. Thank You very much
Regards,
Jim
Regards,
Jim
