I wonder why multi-turn PCB trimpots aren't commonly used to set cathode bias current? Cost, physical size and power dissipation don't seem to be issues. I suspect it has to do with their failure modes. What has your experience been?
Multiple turn trimpots
Peter W.- Posts : 1351
Re: Multiple turn trimpots
j beede wrote:I wonder why multi-turn PCB trimpots aren't commonly used to set cathode bias current? Cost, physical size and power dissipation don't seem to be issues. I suspect it has to do with their failure modes. What has your experience been?
A couple of things:
a) Cost: For us, the hobbyist, the difference between a $0.90 part and an $1.95 part is negligible. Times 1,000 units, not so much.
b) And, here is a good example of the difference between 'accuracy' and 'precision'. Setting bias need only be accurate. Precision is wasted. So, a pot that has enough range to be accurate is all that is required.
If we wish to populate our equipment with "better" parts, that is a great idea, and I am as guilty as anyone else along those lines. But, let's be sure that those parts we use are appropriate to the use and do not introduce needless complexity instead.
Roy Mottram- Admin
in my experience, a $2 or $3 multi-turn pot will very often fail after being turned to one extreme or the other, and where is the end of turning???
I've never had a $1 single turn pot fail, and it has the same adjustment range, and I'd rather turn one 10 degrees than 4 or 5 360 degree turns.
j beede- Posts : 473
My application would benefit from the narrow width of four multi turn pots mounted side-by-side. My suspicion is that there is a reason why these pots are not commonly used. tubes4hifi addressed the issue that I was trying to raise.
CletusB- Posts : 234
Yup!tubes4hifi wrote:in my experience, a $2 or $3 multi-turn pot will very often fail after being turned to one extreme or the other, and where is the end of turning???
