    VTA ST-70 and 12bh7
    fzapped
    VTA ST-70 and 12bh7 Empty VTA ST-70 and 12bh7
    Post by fzapped on Sat May 19, 2018 12:16 pm
    I have a couple of 12bh7a tubes. They work fine as phase splitters (quite) but are noisy (hum) in the center position. 12au7 is quiet in center spot. 2 bad tubes? Wiring error? Any ideas appreciated.
    VTA ST-70 and 12bh7 Empty Re: VTA ST-70 and 12bh7
    Post by Bob Latino on Sat May 19, 2018 12:24 pm
    fzapped wrote:I have a couple of 12bh7a tubes.  They work fine as phase splitters (quite) but are noisy (hum) in the center position.  12au7 is quiet in center spot.  2 bad tubes?  Wiring error? Any ideas appreciated.
    The center driver tube is the voltage amplifier for BOTH channels. The two side tubes are the phase splitter/inverter tubes for that channel alone. Because their of different function in the amp, the two side tubes are relatively immune to causing any hum/noise in the amp.
    fzapped
    Post by fzapped on Sat May 19, 2018 12:27 pm
    Noisy tubes then?
    Sent from Topic'it App
    Post by Kentley on Sat May 19, 2018 12:36 pm
    Yes, fz. I've often used fine old 12BH7s in that center position (my faves are vintage TungSols and Sylvanias) and they are completely silent.
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever on Sat May 19, 2018 12:39 pm
    fzapped wrote:Noisy tubes then?
    Yes, Noisy tubes. Both of your 12bh7s have 60hz "noise" leaking from the heater to the cathodes.
    fzapped
    Post by fzapped on Sat May 19, 2018 12:40 pm
    Since they work as phase splitters my money is not totally wasted.
      Current date/time is Sat May 25, 2019 12:08 am
