    Simple question.........how many watts does my vta st-70 consume?
    islanddave
    Post by islanddave on Sun Jun 10, 2018 9:52 am
    Hello
    I am thinking of using an isolation transformer rated at 900VA........for my system.......vta st-70 how many watts does my amp consume?
    Will this rating of isolation tranformer be appropriately sized?
    Thanks David
    Re: Simple question.........how many watts does my vta st-70 consume?
    Post by audiobill on Sun Jun 10, 2018 9:56 am
    your 900 watt transformer just might work.....
    islanddave
    Post by islanddave on Sun Jun 10, 2018 10:02 am
    audiobill wrote: your 900 watt transformer just might work.....
    I know my amp out puts 35 watts aside so does it also use this much?
    Thanks David
    Post by peterh on Sun Jun 10, 2018 10:04 am
    islanddave wrote:Hello
    Thanks David
    Just a guess : 250w when full power, 120 when idle
    If needed i can measure mine.
    islanddave
    Post by islanddave on Sun Jun 10, 2018 10:25 am
    Thanks David
    How would i measure it.............I have a multi-meter?
    Post by peterh on Sun Jun 10, 2018 11:16 am
    Thanks David
    You need an energy meter , like this :
    https://www.kjell.com/se/sortiment/el-verktyg/el-produkter/starkstrom/energimatare/luxorparts-energimatare-p50003
    it measures current and voltage, takes current delay ( whatever you call it) and
    presents the actual power consumption.
    In addition it can integrate the consumption and multiply with the rate.
    Post by peterh on Sun Jun 10, 2018 11:44 am
    My vta70 consumes 167 - 170w at idle
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever on Sun Jun 10, 2018 7:06 pm
    Short answer is yes your 900va transformer will easily work with your VTA ST-70 without breathing hard.
    pichacker
    pichacker
    Post by pichacker on Mon Jun 11, 2018 7:04 am
    Can I ask why you'd want to use an isolation transformer? The main power transformer in the STxx does this for you.
    Also be aware that the voltage out of the isolation transformer will be slightly different to the line voltage. Given you are looking at a 900VA version it may be higer than you'd like at the load you are pulling. All depends upon the type and quality of transformer used.
    Post by deepee99 on Mon Jun 11, 2018 12:47 pm
    My ST-120 pulls about 3 amps (360 watts); a pair of M-125s will draw about 4.5 amps. All in, not bad. You could do worse than that if you left a few lights on overnight. I read somewhere, though, that tube amplifiers leave a huge greenie "footprint" because their sonic output is about 3 percent of energy consumed -- the rest goes to heat and light.
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever on Tue Jun 12, 2018 10:13 am
    pichacker wrote:Can I ask why you'd want to use an isolation transformer? The main power transformer in the STxx does this for you.
    Excellent point! I was using a 100va isolation xformer to power an AA5 the other day. I had to use a variac between the xformer and the wall outlet due to the output of the xformer being about 5 volts higher than the wall. So, 125 instead of 120 with the load of the radio attached.
    Post by Peter W. on Tue Jun 12, 2018 10:19 am
    Stand-alone isolation transformers (not medical grade) are often bi-directional. They will very slightly raise voltage one way, and very slightly lower it the other.
    Medical grade/instrument-grade devices are one-way and deliver as closely as possible output voltage to match input voltage. It pays to check.
    Post by Peter W. on Tue Jun 12, 2018 10:49 am
    Thanks David
    It can be calculated. Which works with most tube equipment.
    a) Losses: The typical three-transformer stereo tube amp has internal losses of between 6% and 12%. VTA amps have a larger power-transformer than Vintage (OEM) amps, and so will have slightly very slightly larger losses balanced by a lower operating temperature. But, will likely be at the lower end of the range given their quality. Instrument amps will push up nearer the 12%, sometimes more.
    b) Tubes: An EL34 will dissipate about 36 watts.
    A small-signal tube will be somewhere between 6 and 7 watts.
    A 5AR4 is about 10 watts.
    (4 x 36) + (3 x 7) +10 = 175 Calculated watts. Add losses, and +/- 190 watts is fair-enough. Your 900=watt transformer will be fine.
    Post by tubes4hifi on Tue Jun 12, 2018 12:45 pm
    MOST ST70s have a silk-screened label on the rear panel that tell you it uses 175 watts of power, I did see one photo once that said 190 watts.
    Post by Peter W. on Tue Jun 12, 2018 1:00 pm
    tubes4hifi wrote:MOST ST70s have a silk-screened label on the rear panel that tell you it uses 175 watts of power, I did see one photo once that said 190 watts.
    My OEM device has 190 watts on the nameplate. And uses about 180 or so on the meter. There is some dither based on the input signal and volume, but that is very, very small. It has all-Siemens EL34 output tubes.
    https://www.dropbox.com/s/2120l5s2wbjkjrg/IMG_20170212_152635735%5B1%5D.jpg?dl=0
    Post by tubes4hifi on Sat Jun 16, 2018 3:30 pm
    PeterW,
    an oldie but a goodie, and some nice cookies too!
      Current date/time is Sat Mar 23, 2019 3:40 am
