    How should I punch 3" by 3" holes in the original ST-70 cage for additional ventilation?
    bluemeanies
    bluemeanies
    Re: How should I punch 3" by 3" holes in the original ST-70 cage for additional ventilation?
    Post by bluemeanies on Fri Jul 13, 2018 9:09 am
    So reading about heat being contained in a small area I have some concern although I am not sure my concern comes from reading these posts rather than the issue itself. I have an external 2tube dac with 2" of clearance from the top of the dac to the shelf above it. All my shelves are open, meaning there are no front, Back, on sides. Heat to the touch does not exists,however it is warm which is natural an is how I would describe it...warm not HOT.
    With my description do you think a fan is necessary?
    After reading this I am not sure.
    Post by corndog71 on Fri Jul 13, 2018 9:40 am
    bluemeanies wrote:So reading about heat being contained in a small area I have some concern although I am not sure my concern comes from reading these posts rather than the issue itself. I have an external 2tube dac with 2" of clearance from the top of the dac to the shelf above it. All my shelves are open, meaning there are no front, Back, on sides. Heat to the touch does not exists,however it is warm which is natural an is how I would describe it...warm not HOT.
    I don't think so.  Consider old tube TV's.  They used to be ALL tube and they were not well ventilated cabinets.
    Post by Kentley on Fri Jul 13, 2018 9:57 am
    New2Tubez - I forgot completely about the recent thread on the AB board and its properties which mitigate need for TDR. But others - be aware that use of the Weber WS-1 SS rectifier module necessitates some sort of delay, and careful monitoring of AC line voltage.
    bluemeanies - Like the SP-14 pre, your tube DAC is in no danger of overheating. It is only a possible concern for high-power devices such as ST-120s, M-125s, etc.
    New2Tubez
    Post by New2Tubez on Fri Jul 13, 2018 10:04 am
    dmagazz wrote:ahhhh/ nice. very well thought out.
    these supposedly work very good
    https://www.quietpcusa.com/Noctua-Anti-Vibration-Fan-Mounts-NA-SAV2-P1028.aspx
    I got those very ones. In black too!
    Problem is the cage hole perfs are too small. When I tried to pull the fastener through the perf, it snapped. I tried more than one. I really don’t want to make the perfs bigger.
    Dogstar
    Post by Dogstar on Fri Jul 13, 2018 1:12 pm
    I think installing the fan on the back of the cover and having it push air past the transformers is the better configuration from both a performance and appearance perspective.
    bluemeanies
    bluemeanies
    Post by bluemeanies on Fri Jul 13, 2018 10:40 pm
    Thanks Kentley and corndog71
    Appreciate your input.
    Post by Kentley on Mon Jul 16, 2018 10:30 pm
    Dogstar, you are correct re: placement of fans at the rear. I feel much more heat being displaced now that I've taken your advice. An added benefit is even less noise pollution from rotating blades than ever before. Onward and Upward!
      Current date/time is Fri Feb 22, 2019 9:36 am
