    Running a PH-16 into an ST-120 with the 21 step attenuator in phono only system. Any benefit to a preamp?
    seeirwin
    Post by seeirwin on Mon Jul 23, 2018 11:05 pm
    Hello,
    As the title suggests, my setup is a turntable into a PH-16 into an ST-120 with the attenuator knob. Simple! Would there be any benefit to adding a preamp such as the VTA SP-14? Every now and again, I run a DAC into the ST-120 by just swapping the RCA cables, which I don't mind doing.
    Thanks in advance for your perspective!
    Re: Running a PH-16 into an ST-120 with the 21 step attenuator in phono only system. Any benefit to a preamp?
    Post by peterh on Tue Jul 24, 2018 2:27 am
    seeirwin wrote:Hello,
    Yes, you will get a source selector , not a negligible thing in itself but an asset.
    Plugging rca-connectors may cause loud sound that might damage your speakers ( or ears),
    and is not self-evident if someone else should use them.
    Post by Peter W. on Tue Jul 24, 2018 7:39 am
    On the use of a preamp to improve sound quality with VTA70
    Follow this thread for an exhaustive (and exhausting) discussion on the relative virtue of pre-amps.
    seeirwin
    Post by seeirwin on Tue Jul 24, 2018 8:16 am
    Hi. Can you (or anyone else) provide a link to or the title of the thread you're referencing? Thanks!
    Post by peterh on Tue Jul 24, 2018 8:21 am
    http://dynacotubeaudio.forumotion.com/t3782-on-the-use-of-a-preamp-to-improve-sound-quality-with-vta70
    seeirwin
    Post by seeirwin on Tue Jul 24, 2018 8:29 am
    Thank you!
    seeirwin
    Post by seeirwin on Tue Jul 24, 2018 9:00 am
    I did read that entire thread, PeterW. Thank you. I'm not familiar enough with tubes/circuit design/the PH-16 enough to know whether there is an amplification stage that would enable the type of dynamic range you mentioned in your organ symphony example, or whether it's really just getting the RIAA curve applied and the signal up to line level. If anyone wants to weigh in, I'd appreciate it!
    Post by Peter W. on Tue Jul 24, 2018 10:51 am
    I did read that entire thread, PeterW. Thank you. I'm not familiar enough with tubes/circuit design/the PH-16 enough to know whether there is an amplification stage that would enable the type of dynamic range you mentioned in your organ symphony example, or whether it's really just getting the RIAA curve applied and the signal up to line level. If anyone wants to weigh in, I'd appreciate it![/quote]
    First, the disclaimers:
    a) I am not familiar with the PH16 design, but I see no controls on it. With that in mind, I suspect that the unit delivers a line-level output from a conventional magnetic cartridge.
    b) I further suspect that the output is somewhere between 1.6 and 2V. I cannot find actual specifications on the VTA site.
    With that in mind, it is "just one more input" should you decide to use an active pre-amp. And the reasons for using such a device are more-or-less dependent on a whole bunch of 'other factors'. I am unashamedly in favor of active pre-amps. For what that is worth.
    solderblob
    solderblob
    Post by solderblob on Wed Jul 25, 2018 10:58 am
    I asked essentially the identical question in the aforementioned thread.  I have no use for selectable inputs as I am phono-only.
    No clear answer, but it's probably system dependent -- cartridge output and speaker sensitivity would make a difference.
    I was hoping Roy would weigh-in; presumably he's had experience with both configurations...
    So how does your PH-16 sound?  I'm getting ready to buy the kit soon, I hope.
    dave
    Post by tubes4hifi on Wed Jul 25, 2018 1:00 pm
    Dave (solderblob)
    in your particular case I don't see any advantage of having a preamp, your PH16 is doing all the gain and impedance matching you need.
    You could add a small passive box with a switch, but I'm sure you're smart enough to turn off your amp when switching sources anyway.
    In 99.4% of cases, I agree with PeterW on active preamps (I am unashamedly in favor of active pre-amps).
    solderblob
    solderblob
    Post by solderblob on Wed Jul 25, 2018 1:19 pm
    tubes4hifi wrote:Dave (solderblob)
    Thanks Roy,
    I hope "retiring to Las Vegas" doesn't meant we won't be able to buy your kits anymore!!!!
    dave
    Post by tubes4hifi on Wed Jul 25, 2018 1:40 pm
    I have an entire garage full of tube equipment and parts I'll be selling to everyone over the next few years!
    My products are available now on my website www.tubes4hifi.com
      Current date/time is Sat Mar 23, 2019 3:35 am
