    Heathkit tube checker specs
    baddog1946
    baddog1946
    Post by baddog1946 on Sat Aug 04, 2018 9:19 am
    I have a Heathkit TC-3 tube checker and I need the test settings for the newer tube types used in VTA products. Can anyone provide the settings for the following tubes? KT-120, KT-88.
    Any hints where I could find them is also appreciated.
    cheers
    WLT
    WLT
    No TC 3
    Post by WLT on Sat Aug 04, 2018 12:14 pm
    I do not have a TC 3. It is an emission tester but should give good basic results. For my Hickok tester I used the 6550 settings for the KT88 and they work out just fine. If your TC 3 has the 6550 settings it would probably be a good starting point until something more definitive is specified.
    The KT 120 is in the same family as the KT 88/6550 so I think your settings would be the same. The KT 120 may actually have to have higher emissions to be good compared to a KT 88. More of a guess than a qualified answer.
    More responses from this group would be good.
    Re: Heathkit tube checker specs
    Post by Peter W. on Mon Aug 06, 2018 10:59 am
    baddog1946 wrote:I have a Heathkit TC-3 tube checker and I need the test settings for the newer tube types used in VTA products. Can anyone provide the settings for the following tubes? KT-120, KT-88.
    cheers
    http://tubularelectronics.com/Heath_Manual_Collection/Heath_Manuals_T-X/TC-2/TC-2%20TubeData.pdf
    KT88 = 6550
    5881 = 6L6 =~ EL34/6CA7/KT77
    And the Euro-chart is below the main chart.
    Oops - I nearly missed linking the original chart that has such basics as the 5AR5. 6CA7 and such.
    https://archive.org/stream/HeathkitTC2TubeData/Heathkit_TC-2_Tube_Data#page/n7/mode/1up
    Enjoy, as emissions-testers go, the TC3 is amongst the best.
    Last edited by Peter W. on Mon Aug 06, 2018 1:36 pm; edited 1 time in total (Reason for editing : Added original tube chart link.)
    baddog1946
    baddog1946
    Post by baddog1946 on Tue Aug 07, 2018 6:05 pm
    Thanks for the tips gents. I will check out the 6550 settings. much appreciated
    Baddog
      Current date/time is Sat Mar 23, 2019 3:39 am
