    5R4WGB rectifier tube
    billd
    5R4WGB rectifier tube Empty 5R4WGB rectifier tube
    Post by billd on Tue Aug 21, 2018 7:40 am
    I have a pair of M-125s and currently use Genelex GZ34s that I bought from Jim McShane. Someone I was speaking with here in Bangkok (my home) told me that I could use the 5R4WGB as a replacement for the GZ34. In fact, he recommended it. I looked at the Five Volt Fullwave Rectifier Tube chart that Bob Latino posted. The 5R4 has a much higher voltage drop (67 vs. 17) and a much higher Max PV (900 vs 450).
    My tube knowledge is limited. I'd like to know if the 5R4WGB can be used as a direct replacement and what the differences between the two tubes mean in practical terms.
    5R4WGB rectifier tube Empty Re: 5R4WGB rectifier tube
    Post by Bob Latino on Tue Aug 21, 2018 8:08 am
    billd wrote:I have a pair of M-125s and currently use Genelex GZ34s that I bought from Jim McShane. Someone I was speaking with here in Bangkok (my home) told me that I could use the 5R4WGB as a replacement for the GZ34. In fact, he recommended it. I looked at the Five Volt Fullwave Rectifier Tube chart that Bob Latino posted. The 5R4 has a much higher voltage drop (67 vs. 17) and a much higher Max PV (900 vs 450).
    You CAN use a 5R4 rectifier in the VTA M-125 amp if you want and yes a 5R4 does have a higher voltage drop (Vdrop) than a 5AR4. As such, the amp's overall power level will drop a bit. Whether you will actually notice the drop in power or not, I can't say ? Below is the 5 volt full wave rectifier tube list and the characteristics of each tube ..
    5R4WGB rectifier tube Tube_rectifier_comparison
    billd
    Post by billd on Tue Aug 21, 2018 8:14 am
    Thanks, Bob. That's the chart I was referring to in my post. Since my speakers, Bozak Symphony's, have 93dB sensitivity, I wouldn't expect to notice much difference.
    Post by peterh on Tue Aug 21, 2018 9:36 am
    5r4 is a direct heated tube, thus the B+ will rise faster then the consuming tubes and the
    B+ capacitor might encounter a short overvoltage.
    In addition, the spec for 5r4(wgb) states that maximum allowed capacitor is 4uF, used in a M125
    it violates this.
    See https://frank.pocnet.net/sheets/127/5/5R4WGB.pdf
    I would advise not to use in a M125
    billd
    Post by billd on Wed Aug 22, 2018 4:19 am
    Thanks, Peter. Fortunately, this is an academic question but I am confused since Bob said I can use it but you advise against. I wish I understood more about electronics.
      Current date/time is Mon Jun 17, 2019 4:03 am
