    What to do with the front panel octals after adding autobias board.
    dacer38
    dacer38
    What to do with the front panel octals after adding autobias board. Empty What to do with the front panel octals after adding autobias board.
    Post by dacer38 on Fri Aug 24, 2018 8:59 am
    Looking for any mods for the panel octals where the bias was read prior to autobias board. After installing the autobias board the front octals are no longer needed. Is anyone utilizing the space for meters or status LEDs? Even something cosmetic, since the connectors were the ugliest thing on an otherwise beautiful amp.
    dmagazz
    dmagazz
    What to do with the front panel octals after adding autobias board. Empty Re: What to do with the front panel octals after adding autobias board.
    Post by dmagazz on Fri Aug 24, 2018 9:20 am
    if one could figure the voltage/output level where it starts to break up / distorts the output signal, and work out that voltage point to be a lil circuit enacting a VU to be at 80%, and put that in the right octal hole
    then do something similar for the input(V/ input level point of over driving) and put that in the left octal hole
    well....... they would be my hero!!
    Post by peterh on Fri Aug 24, 2018 10:05 am
    dacer38 wrote:Looking for any mods for the panel octals where the bias was read prior to autobias board. After installing the autobias board the front octals are no longer needed. Is anyone utilizing the space for meters or status LEDs? Even something cosmetic, since the connectors were the ugliest thing on an otherwise beautiful amp.
    I would leave them connected. Whenever you are unsure of the autobias it is only a few
    seconds to confirm that bias is ok ( or wrong).
    It's never wrong to have easily accessible checkpoints. If not needed - no harm done. But if needed
    they are of great value.
      Current date/time is Thu Oct 17, 2019 2:52 am
