rjpjnk wrote:Note: I no longer need a buffer for the phono stage because I was able to modify the Schiit Loki EQ input impedance.
In the mood to explore, I opened up the Loki to have a look at its circuits and saw that that it used a 475R resistor followed by a 47.5K shunt resistor to ground at the input to the first SS device (transistor?). I swapped the 47.5K resistor with a 220K and now the input impedance is 220K and the performance seems unchanged. Other than the fact that these components are extremely tiny SMDs it was a simple mod.
The Loki now seems to work perfectly in the PAS 3x tape loop. It now presents the impedance the phono stage is expecting and hence no longer cuts the bass response 6dB when I connect it.
I wonder what the consequences are...
keego38 wrote:rjpjnk wrote:Note: I no longer need a buffer for the phono stage because I was able to modify the Schiit Loki EQ input impedance.
Hi rjpjnk, just wondering if you have any longterm observations on running your PAS 3 with the modification to the Loki. I am thinking of going the same route,
using the PC 6 phono board to drive the Loki. Thanks in advance.
keego
