    Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion
    Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion - Page 4 Empty Re: Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion
    Post by audiobill on Fri Aug 31, 2018 9:54 pm
    I said write to him, not look up a web page.  Again, this thread is far afield.  But since you asked:
    http://dynacotubeaudio.forumotion.com/t3109-vta-tube-buffer?highlight=Buffer
    rjpjnk
    Post by rjpjnk on Fri Aug 31, 2018 10:04 pm
    Audiobill, You have joined every thread I have started and crapped on it. Why do this? Can't you just ignore them? There is a lot of excellent technical discussion here by good folks who love Dynaco and love VTA. Who are you to judge my thread has gone "far afield"?
    "Dedicated to the restoration and preservation of all original Dynaco tube audio equipment"
    rjpjnk
    Post by rjpjnk on Fri Aug 31, 2018 10:21 pm
    audiobill wrote:I said write to him, not look up a web page.  Again, this thread is far afield.  But since you asked:
    This is actually useful. Looks like Roy sold a buffer in 2016. If it is still available I may buy one from him to use with my PH12 to protect the tape out loop. But it cannot be used with a PAS due to power supply limitations unfortunately. Hence, the reason we are looking at FETs.
    The thread you posted includes the following link to a third party buffer that is apparently very similar
    http://glass-ware.stores.yahoo.net/acpcbandusgu.html
    PeterCapo
    PeterCapo
    Post by PeterCapo on Fri Aug 31, 2018 10:23 pm
    Perhaps Roy might consider a finished, standalone version of the buffer that's plug-and-play?
    Post by peterh on Sat Sep 01, 2018 2:25 am
    rjpjnk wrote:
    peterh wrote:You might eat your cake and keep it :-)
    See this buffer that fits inside the PAS and may be powered by the PAS ( it's FET but so what ) :
    https://www.ebay.com/itm/Dynaco-PAS-Preamp-Impedance-Matching-Module-New/302849514977?hash=item46833cdde1:g:4a8AAOSwirFa95Pq
    Peterh, Did you try this buffer yet? I found another one here that looks to be the same circuit.
    https://www.ebay.com/itm/Dynaco-PAS-Preamp-Impedance-Matching-Module-Buffer-New/292704780919
    No. The snailmail is slow across the atlantic
    rjpjnk
    Post by rjpjnk on Sat Sep 01, 2018 10:54 am
    Have you every seen just a bare board or a schematic for a FET buffer like these? Might be fun to build my own using choice parts.
    Found this circuit from Google image search for example. Not sure how to evaluate its suitability. Can anyone identify this circuit?
    Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion - Page 4 30537773648_2cf18e03b8_c
    EDIT: I found what appears to be the original source. Though the article doesn't say who designed the circuit or how well it works.
    https://billthompson.us/bt/dyna-pas3-modifications/
    rjpjnk
    Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion - Page 4 Empty MOSFET buffer completed
    Post by rjpjnk on Tue Sep 11, 2018 12:31 am
    UPDATE: I built the MOSFET buffer in the schematic posted above and it works great. I added two new output RCS jacks to the PAS so now I have the original output and the buffered output next to it. At present I am using the buffered output only to drive the subwoofer. I modified the circuit above slightly by changing the bias resistors from 470K to 1Meg so the input impedance of the buffer is 500K now. It measures great and sounds perfect. No more excessive loading cutting into the bass tone control response. It was only about 5 dollars in parts and a lot of fun to build. MOSFETS are pretty cool. I'd prefer tubes, but since the power supply is pretty limited thought I'd give it a try.
    Spoke with the author, Bill Thompson, and he was very helpful, btw. Nice guy.
    Here is a pic of the finished product on a breadboard.
    Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion - Page 4 43699694225_28081a7d1d_c
    And installed with two new jacks,
    Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion - Page 4 29671219627_98aed4bd9e_c
    logos47
    Post by logos47 on Thu Sep 13, 2018 9:56 am
    As Peter H suggests, an external buffer should bring matters dead to rights. To avoid impedance issues. , a dedicated subwoofer output jack is a very good thing to do. Relative to the work you have already completed, this is a small step. My buffer has variable volume, EQ, and a 3-pole switch to reverse phase and to shut off the subwoofer. I drive two subs to load the room, so this buffer, separate outs from the pre-amplifier has not only corrected the issues you’ve described, but yields great improvements.
    rjpjnk
    Post by rjpjnk on Thu Sep 13, 2018 11:31 am
    If I did go external, I would build one with tubes, but for now the internal MOSFET buffer is definitely doing the trick. I have also now balanced the PAS to perfectly match the VTA ST-70 input impedance on the standard outputs, and am free to load the buffered outputs anyhow I like with no consequences. Woo Ho!
    The PAS sounds great but it sure is a picky beast as far as loading. The stepped attenuator option on the ST-70 makes it a little less suitable for direct connection to a PAS preamp without modification. I am surprised this hasn't been discussed more, especially given that it is trivial to fix. I decided I like the attenuator, so I modified the PAS load resistors to keep the total load where Dynaco intended it to be. The result is excellent and the tone controls now work much better.
    Now onto the next issue... The PAS phono stage is also unbuffered. This makes the tape loop next to useless with any modern equipment. I may experiment with buffering this as well. The reason is I would like to insert my Schiit Loki EQ in the tape loop and use that as an alternative to the PAS tone controls. However, the Loki has an input impedance of only 50K and the PAS phono stage is expecting about 225K. And it is *really* picky about its loading as well for the same reason as the line stage (tone controls in the NFB loop) Well, in this case the "tone control" is actually the RIAA filter, but same principle.
    Using an inverse RIAA filter I swept the phono stage with and without the 50K load and found the bass rolloff is significant when the load is applied. It is down 6dB at 20Hz. Pretty much identical to the results published by audioregenesis.
    So yeah, this PAS is a picky beast. Sounds great though when it is happy.
    Post by peterh on Thu Sep 13, 2018 11:40 am
    I have now received the buffer. And yes, it fits fine and should work fine.
    I do not however have any schematics , the seller refuses thus i will do
    some reverse engineering and publish the findings.
    I have no plans using it in my own set as i already have made buffers for
    both audio out and tape out. Purchase was for evaluation for possible resale.
    ( no i will not copy this, i intend to purchase from the seller, but i refuse
    to sell anything without proper documentation)
    rjpjnk
    Post by rjpjnk on Mon Sep 17, 2018 7:27 pm
    Note: I no longer need a buffer for the phono stage because I was able to modify the Schiit Loki EQ input impedance. Smile
    In the mood to explore, I opened up the Loki to have a look at its circuits and saw that that it used a 475R resistor followed by a 47.5K shunt resistor to ground at the input to the first SS device (transistor?). I swapped the 47.5K resistor with a 220K and now the input impedance is 220K and the performance seems unchanged. Other than the fact that these components are extremely tiny SMDs it was a simple mod.
    The Loki now seems to work perfectly in the PAS 3x tape loop. It now presents the impedance the phono stage is expecting and hence no longer cuts the bass response 6dB when I connect it.
    I wonder what the consequences are...
    wgallupe
    wgallupe
    Post by wgallupe on Tue Sep 18, 2018 9:41 am
    Interesting. Can you post pics showing which resistor to change? I also have a Loki EQ and would like to buffer the phono out on my PH12 which is built into my SP13.
    rjpjnk
    Post by rjpjnk on Tue Sep 18, 2018 11:12 am
    wgallupe wrote:Interesting. Can you post pics showing which resistor to change? I also have a Loki EQ and would like to buffer the phono out on my  PH12 which is built into my SP13.
    Sure, I will get a picture tonight and post it. Good point about the PH12 phono stage. It is also unbuffered I know. What impedance is the PH12 able to accommodate on its outputs without degradation of performance?
    wgallupe
    wgallupe
    Post by wgallupe on Tue Sep 18, 2018 1:25 pm
    I don't know but there's a thread here somewhere that suggests 100K minimum is good. Thanks in advance for the pics!
    rjpjnk
    Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion - Page 4 Empty Schiit Loki mod to work with PAS 3x
    Post by rjpjnk on Wed Sep 19, 2018 1:12 am
    Here is the picture of the Loki with one channel modified. The arrow points to the original 47.5K resistor that gets changed to 200-220K. In this pic I have changed only channel 1. You can see the huge 1/2 watt resistor soldered in place where the tiny SMD used to be. Channel 2 is untouched in this pic.
    Compatibility of Dynaco PAS with VTA ST70, Subwoofers, and other power amps -- INPUT IMPEDANCE discussion - Page 4 42964486430_40081cdb3d_c
    wgallupe
    wgallupe
    Post by wgallupe on Wed Sep 19, 2018 9:21 am
    Excellent! Thanks for posting that. Couple questions: Is a 1/2 watt resistor really needed? Any problems un-soldering the SMD? Or inserting the relatively large resistor leads into the holes on the PCB?
    rjpjnk
    Post by rjpjnk on Wed Sep 19, 2018 9:47 am
    No, the 1/2 watt resistor is not needed. It is just there as an experiment. It is just all I had laying around at the time. I have since ordered some 2mm SMD resistors for pretty.
    That said, there is no reason you can't use a 1/2 or 1/4 watt axial resistor like in the picture if you want. There is plenty of room and they are easier to solder than the SMDs. Regardless of the choice, the leads are soldered on top of the circuit board. There are no holes.
    You need an extremely tiny tip soldering iron and a small flat jewler's screwdriver or tweezers to lift the SMD. And a magnifying glass.
    Post by peterh on Wed Sep 19, 2018 3:34 pm
    Schematic done on paper. Will transfer to printable form later, but no surprises here.
    And i will probably test it in a extra PAS3X i have
    rjpjnk
    Post by rjpjnk on Thu Sep 20, 2018 11:15 am
    Looking forward to your results.
    How will you evaluate it?
    Post by peterh on Thu Sep 20, 2018 12:44 pm
    rjpjnk wrote:Looking forward to your results.
    Not decided yet. Might be a simple listering test, maybe adding some load.
    The nice thing with this design is that it is driven by symmetrical power ( +12v and -12V)
    thus there is no cap charge hump at power on or off. Given that the pilot light is
    replaced by a LED the total load on the transformer is lower then stock version.
    rjpjnk
    Post by rjpjnk on Thu Sep 20, 2018 12:49 pm
    rjpjnk wrote:... I have since ordered some 2mm SMD resistors for pretty.
    Soldered in the tiny 220K SMDs last night and it looks like new again. I taped the original resistors to the inside case in case I ever want to revert back to them. Did a lot of testing of the frequency response and the modified Loki seems to work well with the PAS now.
    One thing to keep in mind though. If anything is plugged into the Tape Out jack and the Tape/Input switch is in the "Input" position, then the impedance of the device attached to the Tape Out appears in parallel to the normal impedance of the Line Stage (That is, vol control, balance control, loudness tap, and 47K series resistor). Maybe this is obvious to many, but some folks may not realize this and it is important because leaving this device plugged in will impact the bass response even though the device is not being used.
    For example, even the modified Loki cannot be left plugged into the tape loop if the Tape/Input switch is in the "Input" position because then the impedance seen by the Phono Stage would be only 110K = (220 Loki) || (220 PAS). It is not a huge problem, and certainly much better than when the Loki was at 50K, but even this small change does impact the bass response.
    Post by peterh on Sat Sep 22, 2018 9:02 am
    FET buffer installed : http://n.manet.nu/pas3/PAS-buffer.jpg
    Or the whole amp:
    http://n.manet.nu/pas3/index.html    Scroll down to last picture
    First impression : sounds ok, no harsh flutes, no noice.
    As for mounting : the metal angles used some strange threds. A M3 threadmaker ( what that is called
    in english ) fixed this.
    The mounting is tight, in aftersight one should solder all wires on the buffer first, then install and
    last solder wires into the PAS at right positions.
    I found a similar item from hongkong :
    https://www.ebay.com/itm/Dynaco-PAS-Preamp-Impedance-Matching-Module-Buffer-New-/292704780919?oid=302723561677
    Seems to be a straight ripoff at a lower price.
    As a comment,
    Mounting 2 of these boards would be hard,
    a buffer with 4 channels could be nice, this would make the tape-out usable.
    rjpjnk
    Post by rjpjnk on Sun Sep 23, 2018 11:43 am
    Well done. Looking forward to the schematic.
    I looked at that Chinese version as well, and spoke with the seller a couple times to inquire about buying unpopulated boards. He would sell 2 for 9.00 + shipping. Problem is the schematic calls for 2SK170 JFETS. These are classic, famous Toshiba parts from back in the 70's I believe, and they are no longer in production. NOS are 20-60 dollars each on ebay. Of course, the Chinese have imitations available for 50 cents. These are the ones included one the board. After more research I found the market is flooded with these fake JFETS with many claiming to be original, but all are actually Chinese rip-offs just marked up sufficiently to make buyers think they are genuine. Sad.
    That's why I built the other circuit.
    Anyway, your whole amp look fantastic. Excellent work!
    Post by peterh on Sun Sep 23, 2018 1:16 pm
    rjpjnk wrote:Well done. Looking forward to the schematic.
    Yes, it's sk170 here too. In a very classical source follower, using another sk170 as
    current source ( source and gate connected together, drain connects to source of
    source-follower)
    I made a schematic on papers, i'll try to upload it.
    ( upload failed, try : )
    http://n.manet.nu/pas3/FET-buffer.jpg
    Post by peterh on Mon Oct 01, 2018 7:57 am
    My dedicated buffer has been overhauled :
    http://n.manet.nu/fm1/second.html
    by installing proper RCA connectors and a general fixup
    To summarize, this former fm1 has 2 pairs of cathode buffers, both for the "amp channel" but
    more importent for me, a buffered tape-out channel to allow computer soundcard to be
    connected. In addition it contains a remote capable volume control and a power sequencer
    to turn on/off pre and power amp, protectimng from power outages.
      Current date/time is Thu Jan 23, 2020 5:35 am
