    Mil spec bias pot
    ttownscott
    ttownscott
    Mil spec bias pot Empty Mil spec bias pot
    Post by ttownscott on Mon Aug 27, 2018 11:51 pm
    Installing a Dynakitparts 10K Mil Spec bias pot. Not sure if the lock washer should be on top or below the chassis?
    Is this right?:
    Mil spec bias pot WUjjIMeCSpXhDT_sM3K3khqmuRPqaotb2nxLIvChdg4py0OciUI1wDIawy7rspdKxmiqkxi5cDdGyQ5waQ3FrWp47BKIRDqOSj8ZzUQ4j7Yo4VHldwzWDTgxi3rv7bf0nXvaAn1feS4RFLXLD1TMCTweUDpV7zJ03HWbkyrLizPe5ROA3izxQGcGhKfm2z8isNXbW-5j9O2to8De8yrOG2t5zhHeha3pqJYBhLJM_l0PhmJqQid9CgBXepnQ5aTuI17_9BXEed2A043GYXRZXyKWNE_rhKGuMvdGXdBLZ47QAbW3PV0SZMx5uyz4lAddbEzEONbTi5UUgtdg58yhC6BP3-5z3V_4OWgWMG9j08vw94NblzQvE7R8ey42nBi4EwB0F8vx25PFPTUOepERKZ8ygz1kj8na11ecQpXzilcfsTWjBIShQWYzsakrDzR2bWjBjJz13BWaM2HDqDbKM9glHNbMJGCN8T_McDwmLo-UG5GjCbmm7B7spTQqY-fhOwKTkG9T3aDGp8QZrYm12E5SKeqkwuddXqiKZIh3UjO3cv_yXANgCYXl08H7VQXpK37GUGgkqL0VIpq-fr3weun8gO6rLwCL1DEcMRBNv99ExxaN_4UuAxVTNOAMGRZ_HbbM1LaWoul4A2TDdBm2K9k23_FUsFiU5VJAL4fH0phbj1-MNON6iv2r=w1185-h889-no?
    Mil spec bias pot Empty Re: Mil spec bias pot
    Post by Peter W. on Tue Aug 28, 2018 1:12 pm
    As long as it is secure, it does not matter. However, traditionally the cap-nut is on top, the lock nut underneath for the pot to be as low as possible. At the same time, the lock-nut allows one to adjust the height if there are clearance issues below, or access issues above.
    PeterCapo
    PeterCapo
    Post by PeterCapo on Tue Aug 28, 2018 2:29 pm
    Those are nice bias pots.
    DynakitParts
    DynakitParts
    Mil spec bias pot Empty 10K Mil Spec pot
    Post by DynakitParts on Tue Aug 28, 2018 7:43 pm
    Hi..
    Installation is correct.....The purpose of the larger top hex nut is to lock the position of the shaft so that it cannot rotate. After setting your bias I would just hand tighten this top nut. Very unlikely the shaft is going to turn by itself unless you have children who like to touch stuff.
    Kevin
      Current date/time is Thu Jan 23, 2020 5:38 am
