    Performance Evaluation of VTA ST-70
    bennytehcat
    Post by bennytehcat on Sat Sep 15, 2018 9:58 pm
    Howdy folks!  Who's ready for today's lab assignment?  You got pants?  Closed-toe shoes?  Lab notebooks?  Fantastic...let's get started!
    Objective: Evaluate the performance of my new VTA ST-70 and kill a Caturday.
    Equipment:
    (1) VTA ST-70 (See here for my interpretation)
    (1) Fluke 115 Multimeter
    (1) Atten ATF20B Digital Function Generator
    (1) Agilent MSO-X 2014A Digital Oscilloscope
    (2) Oscilloscope Probes: 10:1, 150 Mhz, 10M Ohm, 15 pF
    (2) 3' BNC Cables
    (1) BNC Tee
    (1) Female BNC to Male RCA
    (1) Female RCA Mono to Male RCA Stereo
    (2) UX-Cell 8 Ohm 100 Watt Dummy Load Resistors
    (4) Strong Beers
    (1-2) Cats
    Experimental Procedure:
    To start, a beer was opened.  After a short period the 8 ohm reistors were installed on the corresponding output terminals of the amp.  The output of the function generator was connected to a BNC tee which split the signal into two paths.  The first path was converted to the RCA connection and sent to the amplifiers input.  The second path was sent to ch1 of the scope to record the original input signal.  Two scope probes were attached, one to either output channel of the amplifier which then fed into ch2 and ch3 of the scope.  All equipment is powered up and 30 minutes are allowed to ellapse.  Time for a second beer.
    The first step in the diagnostic is checking the bias across all tubes, using the same naming scheme as the VTA assembly guide.
    V2: 423 mV
    V3: 421 mV
    V6: 423 mV
    V7: 425 mV
    Data was then recorded for the following inputs at 200 mV:
    A) Sine at [10,20,100,1k,5k,10k,15k,20k,30k] Hz
    B) Square at [500,1k,10k] Hz
    C) Step at [500,1k,10k] Hz
    The oscilloscope recorded the following:
    Ch1: Original Signal
    Ch2: Left Amp Output
    Ch3: Right Amp Output
    F1: Ch2-Ch3
    As a last step, the bias was checked once again to ensure nothing changed:
    V2: 416 mV (Diff: -7 mV)
    V3: 416 mV (Diff: -5 mV)
    V6: 417 mV (Diff: -6 mV)
    V7: 418 mV (Diff: -7 mV)
    Results:
    All signal traces were read into MATLAB for some simple math and plotting.  This is probably a good time to open the third beer.
    I was curious about investigating 3 main things:
    1) Gain
    2) Signal Reproduction
    2) Difference between Left and Right channel (ch2-ch3 on the scope)
    Gain was measured as V(ch3)/V(ch1).  In the sine signal test, the average gain across the frequency range was 36.6 +/- 0.2 (V/V).  Both channels were in sync in terms of power, but that slipped when the 20 kHz test ran. The square and step test also looked pretty good at 500 and 1k Hz, but they also slipped around 10 kHz.
    If anyone has any suggestions for additional testing, please let me know.
    As for beer #4... Well, now that I'm done that one will be for the next listening session.  We're going with Nicola Conte's Rituals on the TD160.
    Note, all the plots below have the original signal scaled by a factor of 10 to make it visible with the amplified signal.
    Cubdriver
    Re: Performance Evaluation of VTA ST-70
    Post by Cubdriver on Wed Oct 03, 2018 8:04 pm
    Nicely done.  I see a requirement for 1 or 2 cats in your equipment list, but their use in the testing does not appear to be mentioned.  What was their purpose?  In my lab, they serve to knock things off the bench and torture test cables.
    (I suppose it goes without saying that the amp is NOT turned on in this photo.)
    Some one of these years I'll build some good 8 ohm loads and test mine with the HP 8903B audio analyzer to see how it fares.  In my spare time.  Very Happy  (so called because I have so little of it.)
    -Pat
    bennytehcat
    Post by bennytehcat on Wed Oct 03, 2018 8:22 pm
    Cubdriver wrote:Nicely done.  I see a requirement for 1 or 2 cats in your equipment list, but their use in the testing does not appear to be mentioned.  What was their purpose?  In my lab, they serve to knock things off the bench and torture test cables.
    I'm sorry, you are completely right, that was left out of the original instructions.  I see you cats are well trained for their proper roll in the lab and are doing their job correctly. We've recently decided to add pets to our research groups website.  Accordingly, Ben and Rory are working on a project titled, "Analytical and Experimental Investigations of Inertial Impacts From Counter-top Height".  I'm getting very curious about their progress as I've seen an excessive amount of experimentation and very little on the analytical side.
    Cubdriver
    Post by Cubdriver on Wed Oct 03, 2018 8:47 pm
    Don't hold your breath waiting on that analysis...  They are naturally inclined towards the experimental side (gravity driven inertial impacts from various heights being one of their favorite experimental avenues), but have no inclination whatsoever to documenting or analyzing the results of their frequent experiments despite the PhD level effort they expend on said experimentation.
    If the little buggers would document and analyze all they do, we'd likely know all there is to know about gravity by now.
    -Pat
      Current date/time is Thu Jan 17, 2019 8:29 pm
