I recently acquired a Dynaco PAS-3 and am going through the process of restoring it along with a few modifications to improve the sound while staying true to the intent of the design. I am trying to bypass the tone controls and found a great thread on this forum about how to do it on a PAS-3x. Is there any reason that the same modifications wouldn't work on the 3? I know the pots are different, I don't have a 3x to compare to see if the boards are.
Tone Bypass on PAS-3 vs PAS-3
peterh- Posts : 1823
Re: Tone Bypass on PAS-3 vs PAS-3
The boards are identical.drewrf wrote:I recently acquired a Dynaco PAS-3 and am going through the process of restoring it along with a few modifications to improve the sound while staying true to the intent of the design. I am trying to bypass the tone controls and found a great thread on this forum about how to do it on a PAS-3x. Is there any reason that the same modifications wouldn't work on the 3? I know the pots are different, I don't have a 3x to compare to see if the boards are.
How about using it for a while before changing ? Then you could actually compare the
results.
And what are your goal with the proposed changes ? What do you need that a stock PAS
cannot deliver ?
rjpjnk- Posts : 262
Can you send a link to the article you found? I’d prefer to read it before commenting. The 3x is already bypassed when the controls are centered.
Most of what you need to know can be found here:
http://www.audioregenesis.com/documents/PAS%20Tone%20Control%20Bypass.pdf
