    Khozmo Display Mounting?
    Jedidiah
    Post by Jedidiah on Wed Oct 24, 2018 12:48 pm
    What are you folks doing to mount the LED display to the inside the windows of the SP13/14 front panel?
    I am in the process of building my SP14 and realized there are no mounting points on the panel. The pictures i see of builds look to have adhesive of some sort.
    Thanks in advance!
    Re: Khozmo Display Mounting?
    Post by Peter W. on Thu Oct 25, 2018 8:44 am
    Jedidiah wrote:What are you folks doing to mount the LED display to the inside the windows of the SP13/14 front panel?
    Thanks in advance!
    I have not done an SP14, but I have done a number of units requiring the mounting of meters or displays. I don't like tapes or other similar materials as they age badly, leave much behind if removed and so forth. I tend to use hot-melt glue that is also "museum quality". It ages well, may be removed easily, but has very good bonding characteristics.
    One of many sources:
    https://www.gaylord.com/Preservation/Conservation-Supplies/Adhesives/Thermogrip-6363-Hot-Melt-Adhesive-(6-Pack)/p/636315
    Most of the time, the likes of Michael's stocks similar materials.
    Jedidiah
    Post by Jedidiah on Thu Oct 25, 2018 9:57 am
    Peter W. wrote: I don't like tapes or other similar materials as they age badly, leave much behind if removed and so forth. I tend to use hot-melt glue that is also "museum quality". It ages well, may be removed easily, but has very good bonding characteristics.
    hot glue is also my go to for things like this. Unless someone came up with something i was missing, it was likely the route i was going to take.
    thank you for replying.
      Current date/time is Wed Jan 23, 2019 4:31 am
