    FLUX Removal
    StevieRay
    FLUX Removal Empty FLUX Removal
    Post by StevieRay on Mon Nov 05, 2018 10:04 am
    Just starting my VTA ST-120 build...I'm building the circuit boards first (TDR and main board).
    For years I've only removed solder flux from PC boards when doing rework, or when the flux was thick, or used a flux pen for rework to help wick solder up.
    What are your thoughts on the necessity of removing flux residue on new board work, and if you say 'yes', then what methods and materials do you use (preferable stuff around the house or hardware store, without buying some super $$ flux remover)?
    Thanks!
    FLUX Removal Empty Re: FLUX Removal
    Post by Peter W. on Mon Nov 05, 2018 11:09 am
    StevieRay wrote:Just starting my VTA ST-120 build...I'm building the circuit boards first (TDR and main board).
    Thanks!
    If you are using a high-quality 37/63 eutectic rosin-core solder, there should be no reason for flux removal after the fact. Keep the tip clean, hot enough, and don't go all blobs with the solder, and you will be fine. I am assuming that you are using lead/tin solder, not RHoS-compliant solder. Should you be using the latter, there are any number of flux-removers on the after-market should there be too much residue.
    https://gokimco.com//media/catalog/product/cache/1/Base%20Image/9df78eab33525d08d6e5fb8d27136e95/e/s/es1696_2.jpg
    PeterCapo
    PeterCapo
    Post by PeterCapo on Mon Nov 05, 2018 11:25 am
    I like to deflux just for a cleaner appearance to the work.  As long as it is not on any kind of phenolic material, or anything else that might be harmed, then just isopropyl and a good brush should work https://www.mgchemicals.com/products/cleaning-products-for-electronics/cleaning-accessories/brushes/chisel-hog-hair-857   I'd use at least 91% isopropyl, again, provided the alcohol and water won't harm whatever you're cleaning. This is for rosin core colder. Have not used other kinds of solders - not sure what kind of different cleaner they might need.
    StevieRay
    Post by StevieRay on Mon Nov 05, 2018 11:42 am
    I would need to look when at home again this evening, but I believe it's Kester "44" tin/lead (no RHoS for me!).  Very fine gauge.
    I have some silver solder but to be honest I've never really used it but a few times -- and I sit here thinking "why" did I use it at all on a 'normal' audio circuit?
    Post by Peter W. on Mon Nov 05, 2018 11:57 am
    StevieRay wrote:I would need to look when at home again this evening, but I believe it's Kester "44" tin/lead (no RHoS for me!).  Very fine gauge.
    Just be sure that it is eutectic solder (67% tin, 37% lead) and you will be fine.
    cci1492
    cci1492
    Post by cci1492 on Mon Nov 05, 2018 12:55 pm
    New2Tubez
    Post by New2Tubez on Mon Nov 05, 2018 11:52 pm
    I used Kester #44 on my ST-120 and did all my cleaning with an acid brush:
    https://www.homedepot.com/p/Premier-1-2-in-Acid-Brush-144-Pack-HST10127/300333372
    kimwipes:
    https://www.fishersci.com/shop/products/kimberly-clark-kimtech-science-kimwipes-delicate-task-wipers-7/p-211240
    and 99% isopropyl alcohol.
    I picked it up from watching an overkill NASA soldering video on youtube. Painful but I managed to learn a little along the way.
    https://www.youtube.com/watch?v=Vynb_HdEIDU
      Current date/time is Mon Jun 17, 2019 6:11 pm
