    SP-14 Tubes on top - DS2 Preamp – In an open Wood Salamander Shelf.
    aguaazul
    aguaazul
    Post by aguaazul on Fri Nov 23, 2018 3:38 pm
    How much space in inches do you give for heat dissipation in regards to the shelf above?
    Moving some things around, want to be safe.
    Aguaazul
    PS: Looks like this now...
    https://photos.app.goo.gl/qv1bhwUhw7C69Xsx9
    Re: SP-14 Tubes on top - DS2 Preamp – In an open Wood Salamander Shelf.
    Post by tubes4hifi on Fri Nov 23, 2018 4:46 pm
    4-5" above all tubes should be good
    aguaazul
    aguaazul
    Post by aguaazul on Fri Nov 23, 2018 4:54 pm
    Perfect! Thanks Roy.
    Post by deepee99 on Sat Nov 24, 2018 3:00 pm
    Attaboy! Beautiful, insofar as it looks a tad like mine. Smile
    Time for a new hobby. Golf, heroin maybe? You've kinda hit the sweet spot in terms of audio.
    aguaazul
    aguaazul
    Post by aguaazul on Sat Nov 24, 2018 6:42 pm
    deepee99 wrote:Attaboy! Beautiful, insofar as it looks a tad like mine. Smile
    Well here is it today;
    Spinning Vinyl
    Needed to make room for the SL1200MK5 that I just got back from Kevin @ KAB.
    We threw everything at it... except for we got the entry level cartridges, Ortofon Pro-S 10 & 78.
    With those carts I guess we can upgrade the stylus as time goes by.
    There are a few things in the works for audio still, keeps me away from the pool hall, gentleman's clubs & handshake drugs from downtown ;-)
    Got a Red Baron DAC w/ Tubizator Output Stage, working on power modules.
    An ESP P5 - P6 - P99 set up for selectable 78RPM RIAA Phono-Pre
    Bring the ST-120 in from the garage, plug in the KT-88's that came from your basement.
    Cheers,
    Blue
    Last edited by aguaazul on Sat Nov 24, 2018 6:43 pm; edited 1 time in total (Reason for editing : Spelling)
    Post by deepee99 on Sun Nov 25, 2018 3:54 pm
    Spinning Vinyl
    Cheers,
    Blue
    Blue, can you give us an update on the tubes' behaviours? Re: tube ventilation. I'd also give thought to where and how easily all that heated air gets to escape. Long's they're not scrunched up against a corner in a cabinet you should be good. Also to consider, if faced with tight spaces, a little biscuit fan scrounged from a computer or new for $10 will get that heated air moving right along.
      Current date/time is Thu Feb 21, 2019 1:06 pm
