by deepee99 on Fri Jan 18, 2019 1:00 pm
*I wrote all this before Peter's 2nd response, which appears right above this one*
Peter, Holger, et al, thank-you for your thoughts. Peter has stated the scenario I envisioned; Holger the risks. Even puzzled-out well, I am extremely leery of the possibility of *either* human error or mechanical failure (or worse, both) taking out, in the blink of an eye, several thousand hard-earned dollars worth of amplifier, or somehow shooting a healthy dose of DC down the speaker lines and frying a voice coil or three. FWIW, John Bedini's s/s amps could withstand a direct short across the speaker outputs. Not something to try at home, but I saw John actually do it with MY amp and a very hefty signal going in on his bench in Coeur d'Alene. I suppose Mac's autoformers could handle such an abuse for a short period of time, but I never saw Gordon Gow pull that stunt in one of his traveling road-show "clinics." It just ain't done.
That, and given all the cautions I've read about running a tube amp without any load whatsoever, is the reason I posited the question in the first place. Switching speakers tied to the same amp is one thing, but switching dissimilar amps mid-stream is quite another.
There's gotta be a way, still, shy of doubling-down and buying another set of Tylers so each pair is dedicated to its own amp, thus imperiling marital serenity and taking out a 2nd mortgage . . .
*Again, I wrote all this before Peter's 2nd response* but didn't want to toss away a half-hour's worth of typing.
