by Peter W. on Sun Feb 10, 2019 6:17 pm
Update: Pictures tomorrow.
After washing the beast down in WD-40 into a trash-can properly lined with kitty-litter I could see actual components on the boards beneath the sludge and scum - as seen previously. Then a rinse in CRC Electrical solvent to get the last of the hardened lithium grease from the controls and where it had melted all over the bottom of the chassis. . I freed the frozen controls completely, but for the selector switch, using a combination of Liquid Wrench and Kroil. The selector switch is undergoing its "second Kroil" immersion, as I type.
Previously, I had checked all the connections, cleaned the tube sockets and tested the tubes. I applied power without the tubes and got a rock-steady 20 watts, with no discernible heat at the caps or transformers. 20 watts over all that is not-much, so I was not at all surprised that after an hour, I should be getting no significant heat signatures.
Meanwhile, the selector worked free enough for me to set it on the "Spare" position.
More cleaning with a stiff artist's brush and high-proof alcohol. Soaked the knobs in hot ammonia with dish soap, then a tooth brush. More can be done, but I will have to raid my wife's Cream-of-Tartar for that work. Replaced all four feet, did a very brief plate-current match of the output tubes, replaced the tubes and fired up the amp unconnected to anything, spare input shorted. Went to about 80 watts quiescent, rock steady for an hour, no more heat than one might expect anywhere.
Let it rest for 20 minutes. Added speakers and a signal (Dynaco AF6 tuner) - and Thar She Blows - music! Not a trace of hum, buzz or fuzz. Test-point voltage right were they should be. I shut it down after about 40 minutes due to other demands. Next weekend, I will run it for several hours not on the Iso-Variac, and do leak tests, and re-test the various test points. I will also replace the line cord with a polarized cord so that the switch will directly switch the HOT - not that it should matter - and replace the fuse with a 1.5A dual-element rather than the 5A !! conventional fuse in place.
It has already found a home - my son-in-law is interested. So, it must be properly set for polite society in that case, and I will also replace the outputs with truly matched pairs of Telefunkens that I have stored.
I am not so sure, at this point, of whether or not I will replace the boards. This was a 'Factory (Drexel student) kit, with all the various parts-and-pieces riveted instead of screwed. Drilling out all those rivets, what with the marl to worry about getting into the pots and switches ... maybe not.
Again. Voltages are good, things are staying cool, no hum.
Same Link as above now includes additional photos.
