    Subwoofer tube amplifier?
    bbqjoe
    bbqjoe
    Subwoofer tube amplifier? Empty Subwoofer tube amplifier?
    Post by bbqjoe on Thu Jan 24, 2019 8:06 pm
    Don't see any out there.
    Does everyone just SS for their subs?
    Is there no point in it?
    Would any 'ol amp suffice as a separate subwoofer amp?
    There might be a need here, maybe.
    vtshopdog
    vtshopdog
    Subwoofer tube amplifier? Empty Re: Subwoofer tube amplifier?
    Post by vtshopdog on Fri Jan 25, 2019 1:58 am
    Solid state class D seems to rule in sub amps that usually are rated at multiple 100’s of watts.
    I think two main advantages:
    SS Watts are cheap and efficient.
    SS amps generally have a much better damping factor which is desirable at lower audio frequencies to control woofer cone extension.
    Combining above, a SS subwoofer amp is going to work better and be waaaay cheaper than a valve based amplifier.
    Madisound sells a bunch of plate subwoofer amps, Hypex and Rythmik both sell DIY friendly products.
    pichacker
    pichacker
    Post by pichacker on Fri Jan 25, 2019 4:00 am
    And to get the desired low frequency responses would require huge amounts of iron in the output transformers......
      Current date/time is Mon Jan 27, 2020 12:36 am
