    Turn on and turn off procedure
    ImFritz
    Turn on and turn off procedure Empty Turn on and turn off procedure
    Post by ImFritz on Wed Jan 30, 2019 5:55 pm
    Can someone confirm the turn on and turn off procedure for the preamp and the st-120 amp. Which on first and which off first.
    I've come a crossed it a few times and now that i'm looking for it I cant seem to find it.
    cci1492
    cci1492
    Turn on and turn off procedure Empty Re: Turn on and turn off procedure
    Post by cci1492 on Wed Jan 30, 2019 6:31 pm
    Turn on the pre-amp first, then the power amp.
    Post by corndog71 on Wed Jan 30, 2019 7:52 pm
    Turn off the amps first. Then turn off the preamp.
    bluemeanies
    bluemeanies
    Post by bluemeanies on Wed Jan 30, 2019 7:57 pm
    2nd
    ImFritz
    Post by ImFritz on Wed Jan 30, 2019 8:13 pm
    Thanks guys
    Post by sKiZo on Wed Jan 30, 2019 10:42 pm
    Turn either the amp or pre-amp on or off first ... or should that be the other way around ... scratch
    pichacker
    pichacker
    Post by pichacker on Thu Jan 31, 2019 5:37 am
    Skizo.....
    What they are saying is ......
    Preamp ON first them Amp...
    (By doing this you're not amplifying any warm up pops or noises from the preamp and feeding them to the speakers)
    Amp OFF first then Preamp...
    (By doing this you're not amplifying any switch off pops or squeaks from the preamp and feeding them to the speakers)
    Of course if you have an attenuator on the Amp (Why if you have a preamp??) you could always turn this to minimum (Maximum attenuation) and that way it would not make much difference what order.
    ImFritz
    Post by ImFritz on Thu Jan 31, 2019 8:51 am
    pichacker,
    I do have the attenuator on the st-120. Just want to use caution. Thanks again for the explanations peps.
    Post by Peter W. on Thu Jan 31, 2019 9:23 am
    In general, tube or solid-state, with separate components:
    ON sequence:
    All attenuator/VCs at 0
    All items but the power-amp go on FIRST.
    Power Amp ON.
    Off Sequence:
    All attenuators/VCs at 0
    Power Amp OFF
    Everything else OFF
    Keeping in mind that the electronics are typically OK with anything in any sequence. The speakers might not be, and why the sequence matters.
      Current date/time is Thu Feb 27, 2020 11:00 pm
