    ST-120. Which tap for which configuration.
    bbqjoe
    bbqjoe
    ST-120. Which tap for which configuration. Empty ST-120. Which tap for which configuration.
    Post by bbqjoe on Fri Feb 01, 2019 1:58 am
    I have 3 sets of speakers.
    They sound awfully good together with each making up some of the differences lacking in the others.
    They are all 8ohms.
    In one configuration, all paralleled, I get 2.3 ohms.
    In another, (series/parallel) I can get 5.3 ohms.
    Any ideas which configuration would be best, and at which tap?*
    Thanks gang.
    *I have also tried using a 4 speaker switching box with 5 ohm protection, but it really soaks the life and volume out of the speakers when activated.
    Sorry if this sounds stupid, but sometimes I are.
    ST-120. Which tap for which configuration. Empty Re: ST-120. Which tap for which configuration.
    Post by Peter W. on Fri Feb 01, 2019 8:01 am
    bbqjoe wrote:I have 3 sets of speakers.
    They are all 8ohms.
    Thanks gang.
    In general, the configuration that gives you the highest nominal impedance is easiest on the amp. Tube amps are more tolerant of near-short conditions than SS amps, but still not very happy about it. And what you read with a VOM is a static resistance condition, whereas Impedance varies across the audio spectrum.
      Current date/time is Tue Nov 12, 2019 4:05 pm
