    Tube Question
    bluemeanies
    bluemeanies
    Tube Question Empty Tube Question
    Post by bluemeanies on Fri Apr 05, 2019 12:22 pm
    I have the m125's with 8 Genalex Output tubes using a Mullard rectifier tube.
    Is this ok or should I be using the Weber SS.
    Also I have the Mullard M8136 in the front position and the GE 12BH7A in the second position...is this combo ok?
    If not should I go for four of the same?
    Thank you,
    Frank
    LeGrace
    LeGrace
    Tube Question Empty Re: Tube Question
    Post by LeGrace on Fri Apr 05, 2019 12:47 pm
    Which Mullard rectifier?
    bluemeanies
    bluemeanies
    Post by bluemeanies on Sat Apr 06, 2019 9:52 am
    MULLARD GZ33
    Did some research...my m125's for the rectifier sockets were wired with the DIODE MOD. Also my 803d2's are 90db efficient..so I feel a bit better since reading that the Genalex KT88's Output tubes can put a strain on the rectifier tubes.
    Thanks for responding and feel free to add.
      Current date/time is Mon Jan 27, 2020 12:42 am
