I have the chassis with 3 holes on each side that hold the cage on. My ST-70 is missing the screws.
Can someone tell me the size? are they 4-40 1/4"?
Kray wrote:I have the chassis with 3 holes on each side that hold the cage on. My ST-70 is missing the screws.
Bob Latino wrote:Kray wrote:I have the chassis with 3 holes on each side that hold the cage on. My ST-70 is missing the screws.
The holes in the chassis that hold the ST-70 cage on are not for 4-40 screws .. Those holes are for #6 screws. I believe most (if not all) of the original Dynaco ST-70's used self-tapping #6 screws. Try first a 6-32 self tapping screw in your chassis. The modern VTA amp kits use stainless steel 6-32 screws in a tapped hole in the chassis.
PeterCapo wrote:Original Dynaco parts list specified #6 sheet metal screws.
Here are some that retain the original look, as well: https://www.boltdepot.com/Sheet_metal_screws_Slotted_pan_head_Stainless_steel_18-8_6.aspx
