    Adding an internal tube buffer to the PH12
    rjpjnk
    Adding an internal tube buffer to the PH12 Empty Adding an internal tube buffer to the PH12
    Post by rjpjnk on Tue Jun 11, 2019 4:55 pm
    I have a PH12/SP12 combo and all the talk recently about buffered phono stages has got me thinking it would be nice to have. Then I could potentially use the tape loop if I wanted to.
    The neatest solution would be to buy a PH14 to replace the PH12, but I looked at the PH14 board but it appears too big to fit in my 12"x12"x4" chassis where my PH12 & SP12 is now.
    I wonder if I could build a tiny little 2" board with a single tube cathode follower? I already have the B+ and filament supply, so I would only need a few resistors and caps and a tube socket, right?
    Roy: Do you have a little buffer board like this available? I bet there are a number of us PH10/PH12 owners out there that would buy one. If not, do you know of a prefab board that would do the trick? Homemade breadboard would be my last option, in which case all I need is a good schematic recommendation.
    No hurry, just thinking about the next project for a rainy day. I am already planning the transformer upgrade we discussed previously in order to give the regulators more power to work with.
    Appreciate any inputs, or just interesting discussion. Thanks!
    Adding an internal tube buffer to the PH12 Empty Re: Adding an internal tube buffer to the PH12
    Post by Guest on Tue Jun 11, 2019 7:29 pm
    do a 'tube buffer kit' search on Google, and you'll get quite a few options available, that may be your best bet.
    rjpjnk
    Post by rjpjnk on Wed Jun 12, 2019 11:27 am
    Thanks. I did find some little Chinese Ebay boards without power supplies when searching for "small tube buffer circuit board", but I'm not sure I trust these designs. And I don't know if they would integrate well with the PH12 output.
    So in the spirit of learning something new I did a little reading and found tons of info on cathode followers. It seems the most basic circuits use just 3 or 4 resistors and 2 capacitors per channel, and common tube choices are 12au7, 12AX7, 6DT8, 6SN7, among others. I like the idea of a single twin triode handling both channels. I am attracted to the 12au7/12ax7 since I have a lot of them.
    If anyone has a favorite design using one of these tubes I would appreciate it.
    I found the following link very interesting, but it may be over complicating things for my needs. It points out a lot of potential pitfalls in design, and quickly moves on to designs using two triodes per channel (White Cathode Follower). I was hoping to stick to a single tube design.
    http://www.tubecad.com/october99/index.html
    Post by peterh on Wed Jun 12, 2019 2:17 pm
    rjpjnk wrote:Thanks. I did find some little Chinese Ebay boards without power supplies when searching for "small tube buffer circuit board", but I'm not sure I trust these designs. And I don't know if they would integrate well with the PH12 output.
    A good introduction is at merlin blencove's site : http://www.valvewizard.co.uk/accf.html
    In addition i tested a FET-based buffer intended to be mounted inside a PAS, getting the
    minuscule power needed from the filament power.  It's still mounted in a PAS !
    ( similar : https://www.ebay.com/itm/Dynaco-PAS-Preamp-Impedance-Matching-Module-New/303180358355?hash=item4696f522d3:g:2aIAAOSwTm9c-X5E )
    I decoded the schematics, and it's really nothing special. But it works and according to my ears
    it has no negative drawback. As i reverse engineered this i consider this MY work and feel
    free to share on request.
    Cheaper fet buffers are available at ebay.( but many has push-pull , not class A types) I think that
    a buffer should be minimalistic, using only one class-A device and a corresponding resistor.
    Last edited by peterh on Wed Jun 12, 2019 3:28 pm; edited 1 time in total (Reason for editing : Spelling)
    rjpjnk
    Post by rjpjnk on Wed Jun 12, 2019 8:22 pm
    Peter, I remember that FET buffer. I built a similar one for my PAS back then as well. It is a great choice when there is no power to spare from the transformer for sure.
    I want to try a tube buffer this time.
    Thanks for the link.
    Post by tubes4hifi on Sat Jun 15, 2019 2:16 pm
    https://www.ebay.com/itm/TR2-6DJ8-ECC88-E88CC-Tube-Buffer-Pre-amplifier-Preamp-For-DAC-CD-Player-Audio/253615257235?
    $8
    or you can breadboard the PH14 output buffer, probably cost you more than twice as much for the parts
    rjpjnk
    Post by rjpjnk on Sat Jun 15, 2019 9:42 pm
    That is a neat little board Roy, but it requires +-24VDC for the B+. Not sure how I would derive that from the voltages in the SP12.
    Post by peterh on Sun Jun 16, 2019 1:05 am
    tubes4hifi wrote:https://www.ebay.com/itm/TR2-6DJ8-ECC88-E88CC-Tube-Buffer-Pre-amplifier-Preamp-For-DAC-CD-Player-Audio/253615257235?
    $8
    A pity that something that could be a good buffer is deliberatly designed to run the tube well
    below optimum voltage. And if thought to be installed in a tubeamp where proper B+ is
    present.
    Maybe the amp could be redesigned ( resistor changes ?) for proper B+ ? Is there
    a schematics available ?
    rjpjnk
    Post by rjpjnk on Sun Jun 16, 2019 11:19 pm
    $8
    present.
    I'm sure it could be redesigned. I found what appears to be the bare board here and it includes a schematic.
    https://www.ebay.com/itm/Mini-Tube-Amp-Buffer-Circuit-Board-PCB-Bile-Taste-Fit-for-6DJ8-12AU7-Car-audio/112964311060
    I am thinking of using this board to build the PH14 buffer circuit because it would look neater than breadboard. The schematic does not show a grid stopper resistor unfortunately, but looking at the pics it looks pretty easy to add this resistor. Fortunately the 12au7 has the same pinout as the 6DJ8 the board calls for. For 5 bucks it's worth a shot.
    Post by peterh on Mon Jun 17, 2019 4:04 am
    Regarding the buffer board; yes the values of the schematics are off by one or two digits !
    Input cap 1uF ??? When 0.022 would do just fine. R1 here would 270k be fine and allow a more
    stable operation. Feeding it from -25 to +25 is not needed, ground R3 instead of -25, increase to 18k
    C2 may be 0.47uF and use 47k for RL. With these changes a normal B+ in the range of
    200 - 250V would be fine.
    The important is that a small board buffering 2 channels are available.
    Post by tubes4hifi on Mon Jun 17, 2019 2:28 pm
    perfect PCB, yes, and I agree with the value changes Peter made
    Pillo69
    Pillo69
    Post by Pillo69 on Mon Jun 17, 2019 4:11 pm
    peterh wrote:Regarding the buffer board; yes the values of the schematics are off by one or two digits !
    Adding an internal tube buffer to the PH12 Buffer-seguidor-de-catodo
    rjpjnk
    Post by rjpjnk on Wed Jun 19, 2019 10:53 am
    Yes! It is just what I was looking for.
    Would you not add a grid stopper resistor? I see them in many other CF schematics, though not sure they are really necessary.
    Post by peterh on Wed Jun 19, 2019 12:41 pm
    You _should_ add a grid stopper BUT ; you might need to cut the traces close to pin 2 and 7
    and add your grid stopper across the cut.
    The board is not perfect ( components on underside etc ) but lacking alternative it could
    with some work be useful.
      Current date/time is Tue Sep 17, 2019 3:22 am
