    AB for M125?
    LeGrace
    LeGrace
    AB for M125? Empty AB for M125?
    Post by LeGrace on Sun Jun 30, 2019 8:21 pm
    Is latest revision ready for prime time? Jumpy bias on these amps drives me nuts, curious if these are are reliable enough now to assume control?
    bluemeanies
    bluemeanies
    AB for M125? Empty Re: AB for M125?
    Post by bluemeanies on Sun Jun 30, 2019 11:42 pm
    I have the m125's without the AB control and I am using the Genalex Gold Lion KT88's..no jumpy bias here..Jim McShane..I highly recommend.
    Had the Sovtek KT88's and the bias was jumping constantly.
    So based on this I have to assume quality matched tubes are necessary.
    Post by peterh on Mon Jul 01, 2019 1:58 am
    LeGrace wrote:Is latest revision ready for prime time? Jumpy bias on these amps drives me nuts, curious if these are are reliable enough now to assume control?
    It's tubes that is jumpy, not the amp.
    Get a matched quad from a reputable dealer and you will avoid "jumpy bias"
    Post by Bob Latino on Mon Jul 01, 2019 7:25 am
    A steady bias reading is predicated by a steady line voltage. If your line voltage changes even a 1/4 of a volt, then the bias will change noticeably. In some parts of the USA and Canada the line voltage changes quite a bit during the day. As line voltage goes UP so will the bias. A rock steady bias voltage is not absolutely necessary for good sound. Output tubes have a "range" over which they will operate efficiently. The output tubes should be operated in the lower part of that range for good sound AND reasonably long tube life.
    Post by tubes4hifi on Wed Jul 03, 2019 1:58 pm
    I've never had any trouble with steady bias on EL34 tubes, but many many times have had trouble keeping steady bias with KT88 tubes.
    Make sure your bias grid resistors are 100K or less. If you ever run KT120 or KT150 those resistors need to be 51K. (R29-32 on any VTA board)
    KSMITH
    Post by KSMITH on Fri Jul 05, 2019 9:45 pm
    tubes4hifi wrote:I've never had any trouble with steady bias on EL34 tubes, but many many times have had trouble keeping steady bias with KT88 tubes.
    M-125 monos bias nicely with KT120 with no resistor change necessary.  KT150s are a different story IME.
    LeGrace
    LeGrace
    Post by LeGrace on Sat Jul 06, 2019 8:03 pm
    Wish I could say the same. Since installing KT120's my M125 are hypersensitive. My target is 0.6 per tube. Quite common I'll turn the amps on and see a low reading on the order of 0.3. I'll barely move the pots and recheck and they jump to 0.8 to 0.9. Move them back a whisker and bias falls way too low again. Dialing them in is a nightmare. Doesn't help that my line voltage is up and down like a toilet seat.
    The AB boards I'm hoping can be my salvation. Surprised though that no one has chimed in yet and said I've done this mod and they are great.
    KSMITH
    Post by KSMITH on Mon Jul 15, 2019 8:48 pm
    My house has its own transformer. I do run a variac to reduce but my voltage is fairly steady throughout the day and night. The utility LTC seems to be set at 122 VAC with a deadband of +/- 3 VAC from my observations. Bottom line is my line voltage is very clean and solid. From what I read that is not always the case.
    Post by deepee99 on Wed Jul 17, 2019 10:05 am
    KSMITH wrote:My house has its own transformer.  I do run a variac to reduce but my voltage is fairly steady throughout the day and night.  The utility LTC seems to be set at 122 VAC with a deadband of +/- 3 VAC from my observations. Bottom line is my line voltage is very clean and solid.  From what I read that is not always the case.
    I thought that only existed in fairy tales Smile
    costerdock
    Post by costerdock on Thu Jul 18, 2019 7:02 pm
    I have no problem with bias - mine have been running strong for close to 8 years?
    Post by deepee99 on Thu Jul 18, 2019 7:07 pm
    costerdock wrote:I have no problem with bias - mine have been running strong for close to 8 years?
    Wow, eight years, same tubes? Where's your bias set?
    costerdock
    Post by costerdock on Thu Jul 18, 2019 7:31 pm
    Not same tubes - I got about 6 years out of my Sovtek KT88s - my favorite tubes.
    I've since used KT88 Gold Lions - lost one - then replaced all with Sovtek 6550 which I'm very happy with.
    I run two tubes in each amp with the bias at 500.
    Post by deepee99 on Thu Jul 18, 2019 8:34 pm
    I think that bias setting is your secret. I keep mine at .475 and can't hear a bit of difference between that and the .62 maximum allowed (at least in VTA amps. Hopefully the payoff will be in longer tube and transformer life.
    costerdock
    Post by costerdock on Thu Jul 18, 2019 8:40 pm
    Yeah - I used to do closer to .600 - then backed off from that - and was glad to hear Bob recommending 1.0 and .5 vs 1.2 and .6 (for M125 4 tube setup vs 2 tube setup - I prefer the 2 tube setup.)
    I also had less rectifier issues.
    Post by deepee99 on Thu Jul 18, 2019 8:58 pm
    Good thinking, if great minds think alike.
    I ran my TS 6550s (old US-made) down to .450; anything below that and you could hear a little mud. .475 seems to be their 'company notch.'
    I think I read somewhere that running output tubes at too-low of a bias is just as hard on them as over-biasing. Anyone else hear anything like that and explain why?
    KSMITH
    Post by KSMITH on Fri Jul 19, 2019 6:01 pm
    400 amp service at the end of a dirt road.... Laughing
    Post by corndog71 on Fri Jul 19, 2019 7:24 pm
    deepee99 wrote:Good thinking, if great minds think alike.
    I’ve been told that for longer life, power tubes should be run at half their max dissipation.
    LeGrace
    LeGrace
    Post by LeGrace on Sat Jul 20, 2019 2:53 pm
    Just received from Erhard-Audio:
    https://www.amazon.ca/photos/share/6yJisLnNKx4fVlrFjxiHHhQJo6yPz3dPsgS74xJxgSu
    The AB boards appear high quality.
    Edit: Let me know if link works
    New2Tubez
    Post by New2Tubez on Sat Jul 20, 2019 6:03 pm
    LeGrace wrote:Just received from Erhard-Audio:
    Link works (picture of 2 AB boards w/ caps, resistors and standoffs)
    LeGrace
    LeGrace
    Post by LeGrace on Sat Jul 20, 2019 6:10 pm
    Thanks for confirming. First time using Amazon photos. Tried to paste pic directly into post but didn't work out so this will have to do until I can figure it out.
    Post by deepee99 on Sat Jul 20, 2019 6:13 pm
    No joy here on pics but they are nicely built.
    LeGrace
    LeGrace
    Post by LeGrace on Thu Jul 25, 2019 4:20 pm
    This weekend planning to start the build. Nervous but hopeful as well.
    Post by deepee99 on Thu Jul 25, 2019 5:47 pm
    LeGrace wrote:This weekend planning to start the build. Nervous but hopeful as well.
    You'll do fine. Not speaking on his behalf, but Holger @ Earhart Audio is very handy with these things and do it right. Enjoy!
    LeGrace
    LeGrace
    Post by LeGrace on Mon Jul 29, 2019 6:25 pm
    Not an easy upgrade, really struggling on the first one. Installing all the wires onto the bottom of the AB board turned out to be a major mistake. Instructions say this is the neater option, more like the impossible option. Had to take a break got so frustrated. Will go at it again in the morning.
    LeGrace
    LeGrace
    Post by LeGrace on Wed Jul 31, 2019 8:31 pm
    Way less tricky installing the board first then attaching wires to top side. Still working on some issues but looking forward to benefits of this mod.
      Current date/time is Thu Feb 27, 2020 9:40 pm
