    passive preamps
    passive preamps
    Post by earless on Sun Jul 04, 2010 4:44 pm
    Hello. Anyone have any experience with passive premps and ST 70s?
    Re: passive preamps
    Post by Bob Latino on Mon Jul 05, 2010 9:32 am
    Passive preamps, whether transformer or resistor based, work just fine with all the Dynaco tube amps that I have tried them with. Most CD players are set up for about 2 to 2.1 volt output. Most Dynaco amps only need a little more than 1 volt for full output. Most upgrade driver boards for Dynaco amps will allow the amp to achieve full output with even less input voltage.
    The biggest advantage to a passive is that it nearly always will add less of any "sonic signature" to the music than a powered preamp.
    Re: passive preamps
    Post by GP49 on Tue Jul 06, 2010 4:47 pm
    I can say nothing bad about the performance of going passive with a Dynaco Stereo 70 or other typical tube amplifier. Note that the volume potentiometer (multiple is the best way since not all recordings are ideally balanced left/right) should be of top quality.
    With solid state equipment, the low input impedance "seen" by the source could be a problem. Not all tubed phono stages and output stages on tubed CD players like low input impedances; you'd be setting yourself up for a bass rolloff if the equipment is thus mismatched.
    Re: passive preamps
      Current date/time is Mon Mar 19, 2018 6:08 pm
