Mr. C
Mr C wrote:Thanks Blob. Taking a closer look at PH-16 it sure seems impressive. And If I read correctly it'll handle almost any MM cartridge. That's very appealing to me. That's what I was trying to get out of this thread. Why the SP-12 over the SP-14?
No, I think you still need a SUT for the really tweaky stuff. MMy PH-16 tracks right down the middle about about 3.3 uV cart output. They're 6922-powered but you can do a whole lot better with better tubes.Dave_in_Va wrote:I think that if you use a MM cart. the PH 16 is overkill. I think.
Dave, the Ortofon 2m Black outputs about 3.3uV if I remember. The DP switches on the PH-16 are probably already set for the 47kOhm recommended by Ortofon. So basically, plug-and-play.Dave_in_Va wrote:I think I must have a PH 15 (?). 6922 type tubes but no dip switches for MC. I thought the dip switches were for MC carts.
I know there are some really low output MC carts that probably need something really expensive to work.
Roy, it would neat to have a page of discontinued models so we know what's what.
rjpjnk wrote: All of Roy's products are excellent and you really cannot go wrong, especially as a DIY kit. Your plan to build the PH14 first sounds like a good approach.
Tube Nube wrote:What record player are you using, Dave?
deepee99 wrote:Nothing to be ashamed of, Nube, nothing to be ashamed of.
Current TT iterations all seem to require about $3,000 of sound-proofing but don't really sound as good as my Thorens or your Linns unless you tape a quarter to the top of the non-removable headshell, too.
solderblob wrote:I got it.
Dave
