I couple of days ago I noticed my left channel had a drop in volume. I swapped the input cables and it stayed on the left channel. I swapped the speaker cables and and it moved over to the right speaker. I swapped the power tubes side to side and it stayed on the left. I swapped the outer driver tubes and it stayed on the left. I haven't put it on the bench yet. What should I be looking for, or at, once I get it on the bench?
Left channel sounds deminished, lower volume. ST-120
Mr C- Posts : 99
peterh- Posts : 1823
Mr C wrote:I couple of days ago I noticed my left channel had a drop in volume. I swapped the input cables and it stayed on the left channel. I swapped the speaker cables and and it moved over to the right speaker. I swapped the power tubes side to side and it stayed on the left. I swapped the outer driver tubes and it stayed on the left. I haven't put it on the bench yet. What should I be looking for, or at, once I get it on the bench?
Look for a repair man !
cci1492- Posts : 331
peterh wrote:Mr C wrote:I couple of days ago I noticed my left channel had a drop in volume. I swapped the input cables and it stayed on the left channel. I swapped the speaker cables and and it moved over to the right speaker. I swapped the power tubes side to side and it stayed on the left. I swapped the outer driver tubes and it stayed on the left. I haven't put it on the bench yet. What should I be looking for, or at, once I get it on the bench?
Ouch! I would check for cold solder joints, try a new phase inverter, check caps in place with cap checker (unlikely as this is a new build).
LeGrace- Posts : 388
Double check PIO coupling caps, values should be a close match within pairings.
rjpjnk- Posts : 262
Swap the center tube with one or both of the PI (side) tubes to see if anything changes. The center tube has two triodes in it: one for left and one for right. After that it's off to the bench.
