    a output transformer quandry
    4MarkNY
    4MarkNY
    a output transformer quandry Empty a output transformer quandry
    Post by 4MarkNY Tue Nov 05, 2019 9:05 pm
    I'm doing a second VTA-70 build that I've had in the works for some time. Last year I had a bad output tranny in my working ST-70, so I used one from that old equipment an put that amp back in the line up. Now... the question is, when building this new rebuild should i order a single new A-470? Will they have different characteristics after all these years, or should i expect that I can Mix in a modern one from dynakit parts. and have it work with the old, as long as that old one is in spec?
    Second part. I had the old chassis chromed ( a buddy owns a plating shop.) Anyone know where I could get the chassis screen-printed ?
    Thanks for you opinions. Im obviously not an EE!
    Mark
    a output transformer quandry Empty Re: a output transformer quandry
    Post by Guest Wed Nov 06, 2019 12:03 am
    Post by peterh Wed Nov 06, 2019 4:09 am
    4MarkNY wrote:I'm doing a second VTA-70 build that I've had in the works for some time. Last year I had a bad output tranny in my working ST-70, so I used one from that old equipment an put that amp back in the line up. Now... the question is, when building this new rebuild should i order a single new A-470? Will they have different characteristics after all these years, or should i expect that I can Mix in a modern one from dynakit parts. and have it work with the old, as long as that old one is in spec?
    Mark
    You never know .. If you dont change both you might forever seek and possibly find diffrences.
    The easy solution is to change both and sell the old on ebay, thus recovering most of the money
    for the second a470.
      Current date/time is Fri Apr 19, 2024 6:14 am
