    Very low bias and hum on Dynakit ST-70
    Very low bias and hum on Dynakit ST-70 - Page 2 Empty Re: Very low bias and hum on Dynakit ST-70
    Post by peterh on Wed Dec 04, 2019 6:11 pm
    lagwil wrote:Nope but I do have a 5U4GB and exactly the same resultat with that rectifier. Alao swaped all EL-34 Tubes. Same...
    Time for a scope ( with > 500V probes) to look for that actual rectifier of the B+.
    The midpoint red-yel should be grounded, the red wires connected with the
    gz34 at pin 4 and 6 should be examined for symmetrical voltages. At pin 8 of gz34
    look for the 435V and the pulsating peaks from both sides of the rectifier.
    The humming transformer indicated unbalance from DC magnetizing , as if one side
    of the rectifier don't work.
    lagwil
    lagwil
    Post by lagwil on Wed Dec 04, 2019 6:17 pm
    mijohn wrote:Could an overstressed power transformer be causing the problem and producing the mechanical hum, it's rated for 220V and you're giving at least 235V. A Dynakit PA521 transformer rated at 240V would be better for your area.
    PA521 is what I have.
    /Wilhelm
    Post by peterh on Wed Dec 04, 2019 6:28 pm
    PA521 is what I got.
    /Wilhelm
    Du kan höra med http://www.lh-musik.se/ för reparation
    lagwil
    lagwil
    Post by lagwil on Wed Dec 04, 2019 6:44 pm
    /Wilhelm
    Tack för tipset! De skriver iofs att ”vi tar inte emot HiFi”
    /Wille
    mijohn
    Post by mijohn on Wed Dec 04, 2019 7:40 pm
    /Wilhelm
    That's good, you have the right transformer. I made that comment because you wrote that the amp was stamped 220V.
    PeterCapo
    PeterCapo
    Post by PeterCapo on Wed Dec 04, 2019 11:24 pm
    lagwil wrote: ... I use a slow 1,5A fuse since it is a 220V amp.
    /Wilhelm
    Thank you, I did not realize that.
    lagwil
    lagwil
    Post by lagwil on Thu Dec 05, 2019 10:14 am
    /Wilhelm
    Peter, är det du som är Mr Tubular Well?
    Post by peterh on Thu Dec 05, 2019 12:04 pm
    lagwil wrote:
    /Wilhelm
    Yes
    lagwil
    lagwil
    Post by lagwil on Thu Dec 05, 2019 5:29 pm
    @peterh I just ordered a new GZ34 from you!
    PeterCapo
    PeterCapo
    Post by PeterCapo on Thu Dec 05, 2019 7:23 pm
    Cool beans. Would be fun to come over there for a visit and buy some tubes!
    Post by peterh on Fri Dec 06, 2019 4:41 am
    lagwil wrote:@peterh I just ordered a new GZ34 from you!
    Thanks for that. It's in the post together with santa claus million parcels!
    Post by deepee99 on Sun Dec 15, 2019 11:28 pm
    Maybe a loose (or too tight) transformer bolt?
    Rick Green
    Rick Green
    Post by Rick Green on Mon Dec 16, 2019 11:31 am
    Hello , I am curious if you have resolved your hum problem? If so what was it? I suspect it is coming from the main transformer mechanically. It would be nice to see where the amp is located some pictures of what it is sitting on in its normal environment. Can you measure the loudness of the hum or is it just perceptible? Is the hum 50 Hz or 100Hz?
    lagwil
    lagwil
    Post by lagwil on Tue Dec 17, 2019 4:47 am
    Rick Green wrote:Hello ,  I am curious if you have resolved your hum problem? If so what was it? I suspect it is coming from the main transformer mechanically. It would be nice to see where the amp is located some pictures of what it is sitting on in its normal environment. Can you measure the loudness of the hum or is it just perceptible? Is the hum 50 Hz or 100Hz?
    Hi, no the hum is not solved. I tried two different GZ34 rectifiers and both gives only 0.44 V bias. Something is definitely wrong. I will try to get some professional help to solve it.
    lagwil
    lagwil
    Very low bias and hum on Dynakit ST-70 - Page 2 Empty *** SOLVED ***
    Post by lagwil on Sun Feb 02, 2020 12:48 pm
    At last I found the problem with the help of a professional Dynaco repairman! The new quadcap was broken.
      Current date/time is Thu Feb 27, 2020 9:36 pm
