    PH-14 build, Any tips or advice?
    Mr C
    Mr C
    PH-14 build, Any tips or advice? Empty PH-14 build, Any tips or advice?
    Post by Mr C on Wed Jan 08, 2020 4:44 pm
    I've had my ST-120 for a few months now and I just love it. So I thought I'd continue down the vacuum tube highway. I ordered a PH-14 phono amp kit. I would love to see pictures of other builds. Post them if you have them. Specifically showing how the case is wired up. I have the PCB finished. I'm waiting for some coax and hookup wire from Roy that was missing. I have his newest case, all black. He calls it the "A" case I think with a LED switch and an AC input filter with an integrated fuse. I haven't been able to find any clear pictures of a wired up case. He mentioned in an email that that version doesn't need a terminal strip for the AC power. I don't see that in his instructions. So at the moment that's a little muddy to me. If you have any tips or advice on putting this together I'd love the hear from you.
    PH-14 build, Any tips or advice? 20200110
    PH-14 build, Any tips or advice? Empty Re: PH-14 build, Any tips or advice?
    Post by tubes4hifi on Thu Jan 09, 2020 1:04 am
    some photos sent directly to you via email, along with an updated build manual.
    Mr C
    Mr C
    Post by Mr C on Sun Jan 12, 2020 2:19 pm
    Thanks for your help Roy. Submitted for your approval: Here is a photo of my power wiring
    PH-14 build, Any tips or advice? 20200111
    Mr C
    Mr C
    Post by Mr C on Sun Jan 12, 2020 11:28 pm
    Finished it this afternoon, It checked out fine. I got it in the system and it sounds fantastic. No hum. Just played a little with it this evening. Tomorrow I'll I give it a good shake down.
    PH-14 build, Any tips or advice? 20200112
    DavidR
    DavidR
    Post by DavidR on Mon Feb 03, 2020 10:57 pm
    Looking good. What tubes (brand) did you go with and do all 3 need to be matched or just Left/Right channel tubes ?
    Post by tubes4hifi on Mon Feb 03, 2020 11:00 pm
    all 3 tubes are used for both left and right channels. In almost all cases, tube balance is close enough not to worry about,
    but you can always special order "matched sections" for tubes
    DavidR
    DavidR
    Post by DavidR on Tue Feb 04, 2020 7:48 pm
    tubes4hifi wrote:all 3 tubes are used for both left and right channels.   In almost all cases, tube balance is close enough not to worry about,
    I prefer using NOS driver tubes and it's difficult to get a matched pair never mind 3 matched tubes.
    What brand do you sell and or prefer?
    Post by tubes4hifi on Tue Feb 04, 2020 8:14 pm
    I don't really sell tubes as such, although I stock a bare minimum as required to support the preamp kits I sell.
    There are literally thousands of tubes available, hundreds of brands, and hundreds of dealers.
    TubeDepot offers matching and balancing of tubes. NOS tubes are typically more than $100 each.
    TCtubes offers tested vintage tubes
      Current date/time is Thu Feb 27, 2020 11:17 pm
