    PH14 LED switch brightness
    Mr C
    Mr C
    PH14 LED switch brightness Empty PH14 LED switch brightness
    Post by Mr C on Fri Jan 31, 2020 2:09 pm
    I been breaking in my PH14. If I had one complaint it would be that the LED switch is too bright. I'd like to dim it a bit. I'm thinking adding a 1/4w 330ohm resister. Is there a different value I should consider. Assuming I'd but it inline on the red wire, does it matter red or black?
    PH14 LED switch brightness Empty Re: PH14 LED switch brightness
    Post by tubes4hifi on Sun Feb 02, 2020 6:54 pm
    on either wire should work fine
    buchela
    Post by buchela on Mon Feb 03, 2020 4:28 am
    I used a Sharpie marker, an all bothersome L.E.D.s, works for me.
    colin86325
    Post by colin86325 on Mon Feb 03, 2020 1:51 pm
    Could you use clear (or colored) plastic film that has been buffed with sandpaper to opaqueness?
    Mr C
    Mr C
    Post by Mr C on Mon Feb 03, 2020 3:58 pm
    It's an LED integrated into the switch. Not a separate light. It's the brightest light in the rack.
    Post by tubes4hifi on Mon Feb 03, 2020 11:10 pm
    it's a nice switch . . .
    PH14 LED switch brightness Blue LED switch
      Current date/time is Thu Feb 27, 2020 10:26 pm
