    Speakers Pop on turnoff
    eminence1963
    eminence1963
    Speakers Pop on turnoff Empty Speakers Pop on turnoff
    Post by eminence1963 on Thu Feb 13, 2020 7:30 pm
    My Speakers are popping when I turn the power amps off. Suggestions on what I should do? I have the ST120 and my PL Prologue 5 plugged into a Panamax MR5100. Not a good idea to plug these into the panamax? I did not have this problem with my other setup prior to me adding in the ST120 and SP14, which I just got this month.
    Speakers Pop on turnoff Empty Re: Speakers Pop on turnoff
    Post by corndog71 on Thu Feb 13, 2020 9:51 pm
    Are you shutting the amp off first?
    eminence1963
    eminence1963
    Post by eminence1963 on Thu Feb 13, 2020 10:37 pm
    corndog71 wrote:Are you shutting the amp off first?
    Yes
    10-E-C
    10-E-C
    Post by 10-E-C on Fri Feb 14, 2020 6:33 am
    Yes
    After you turn your amp off first, are you waiting about 45 seconds for the caps to discharge before turning off your pre amp and source?
    Brap
    Brap
    Post by Brap on Fri Feb 14, 2020 10:58 am
    FWIW, in my system (Parasound pre-amp, VTA ST-70) is to mute the preamp first then power down the ST-70. Issue solved.
    eminence1963
    eminence1963
    Post by eminence1963 on Fri Feb 14, 2020 11:44 am
    10-E-C wrote:
    Yes
    Not even turning the preamp off. Just the amps, and pop.
    eminence1963
    eminence1963
    Post by eminence1963 on Fri Feb 14, 2020 11:48 am
    Its one of the 4 powered subs that's causing the issue. Now its on to process of elimination on which one.
      Current date/time is Thu Feb 27, 2020 11:11 pm
