Is there an easy way to wire the selector switch to use the tape head input as an additional phono input? The only mod I've seen requires changing the original RIAA EQ. I would like to keep it close to factory. Thx
Dynaco Pas Phono Input
peterh- Posts : 1832
Re: Dynaco Pas Phono Input
Yes, read the manual.rudes wrote:Is there an easy way to wire the selector switch to use the tape head input as an additional phono input? The only mod I've seen requires changing the original RIAA EQ. I would like to keep it close to factory. Thx
Basically move the equalisation components to the board.
It has been a thread here too, maybe someone with better memory can
giva a hint
peterh wrote:Yes, read the manual.rudes wrote:Is there an easy way to wire the selector switch to use the tape head input as an additional phono input? The only mod I've seen requires changing the original RIAA EQ. I would like to keep it close to factory. Thx
giva a hint
See p.12 on the PAS assembly manual, at right :
b. Magnetic Phono Cartridge
A second magnetic phono cartridge can be connected on the right channel by wiring a short link of wire from lug #9 to lug #11 of switch wafer B (solder both). For the left channel, connect a wire between lug #3 and lug #5 of wafer B (solder both).
Audiokarma has a thread about the subject, some of the advices are, in my opinion
mooth ( avoid changing the riaa eualisation, it's good as is, the curacio makes it
less good)
https://audiokarma.org/forums/index.php?threads/dynaco-pas-3x-how-to-hook-up-or-rewire-for-2-turntables.769240/
