    Dynaco PAS-3 volume notch
    ViperZ
    ViperZ
    Dynaco PAS-3 volume notch  Empty Dynaco PAS-3 volume notch
    Post by ViperZ on Sun Mar 15, 2020 11:54 pm
    I have read several threads about volume notch at around 12:30-1 o'clock on volume dial of PAS-3. I hate it on mine - there is a severe jump in volume at 12:30. My original volume control was uneven, so I replaced it with 4-pin Alps 250Kx2 volume pot, so it still had Loudness - it is super even now. Then I disconnected loudness switch today, as per Curcio instructions, and reconnected 4th pins to bottom/ground pins through resistors. I still have this notch...
    So is the only way to get rid of it is to replace my 4-pin Alps with 3-pin pot? Thank you.
    Dynaco PAS-3 volume notch  Empty Re: Dynaco PAS-3 volume notch
    Post by peterh on Mon Mar 16, 2020 3:14 am
    ViperZ wrote:I have read several threads about volume notch at around 12:30-1 o'clock on volume dial of PAS-3. I hate it on mine - there is a severe jump in volume at 12:30. My original volume control was uneven, so I replaced it with 4-pin Alps 250Kx2 volume pot, so it still had Loudness - it is super even now. Then I disconnected loudness switch today, as per Curcio instructions, and reconnected 4th pins to bottom/ground pins through resistors. I still have this notch...
    Why not just disconnect the loudness taps on the pot ??
    Avoiding the "advice's" from Curcio might be wise ...
    PeterCapo
    PeterCapo
    Post by PeterCapo on Mon Mar 16, 2020 6:28 am
    +1
    ViperZ
    ViperZ
    Post by ViperZ on Thu Mar 19, 2020 3:43 pm
    Thank you both. I lifted those 4.7K resistors essentially leaving Loudness taps floating, and the volume control works perfectly now.
    Now onto figuring out phono wiring in this PAS-3, since it starts humming at like 10 o'clock on the volume.
      Current date/time is Fri Apr 10, 2020 7:12 am
