    Sound Valves VTP101i / Pas3 II clone kit?
    skypilot_one
    Sound Valves VTP101i / Pas3 II clone kit? Empty Sound Valves VTP101i / Pas3 II clone kit?
    Post by skypilot_one Mon Feb 13, 2012 6:15 pm
    Does anyone make a preamp kit that is a single ended, class A, cathode follower circuit with regulated heater and B+ power supplies using low noise rectifiers and has a cathode follower phono stage? Tone controls would be nice too.
    I would like to find one that uses either six 12AX7 or 6SN7 tubes. Any thoughts?
    Sound Valves VTP101i / Pas3 II clone kit? Empty Re: Sound Valves VTP101i / Pas3 II clone kit?
    Post by TMadden Wed Feb 15, 2012 12:44 pm
    That sounds alot like the preamp I built and listen to every day! It's this preamp :
    http://www.tubes4hifi.com/pre11.htm#SP9 and the PH14 phono preamp on this page:
    http://www.tubes4hifi.com/pre11.htm#PH14. Roy sells the PH14 with it's own power supply, but I have mine powered from from the SP9's supply with no issues. The combo sounds fantastic! The line stage uses 12AX7's, the phono stage uses 2 6922's and a 12AU7.
      Current date/time is Tue Mar 19, 2024 7:26 am
