    Changing VTA board to lower-gain
    myaddiction
    myaddiction
    Changing VTA board to lower-gain Empty Changing VTA board to lower-gain
    Post by myaddiction Thu Aug 05, 2010 10:10 pm
    I would like to change my hi-gain VTA board in my ST-70 to a lo-gain. I have aready replaced the center tube with a 12AU7. I would like to know which resistors I change, and to what value.
    thanks,
    Bill
    Changing VTA board to lower-gain Empty Re: Changing VTA board to lower-gain
    Post by Bob Latino Fri Aug 06, 2010 6:00 am
    Hi Bill,
    Below are the resistor sets for the standard gain and the lower gain driver boards. The numbers on the right side are Mouser Electronics part numbers. Some of the numbers could be out of date and changed.
    An asterisk notes which resistors are different between the two board configurations
    Unless noted all resistors are 1/2 watt
    R40 - R43 are not on the board but are the 4 bias resistors
    R44 is a 2.2K resistor that is not on the board but goes between sections 3 and 4 of your quad cap
    Changing VTA board to lower-gain Standardgainboard
    Changing VTA board to lower-gain Lowgainboard
    Changing VTA board to lower-gain VTAdriverboardNEW_sideways-1
    myaddiction
    myaddiction
    Post by myaddiction Fri Aug 06, 2010 7:12 am
    Bob thanks. You mention the (4) bias resistors, and the resistor on the quad cap, but there is not an asterisk by them. So I replace them also?
    Post by Bob Latino Fri Aug 06, 2010 7:37 am
    myaddiction wrote:Bob thanks. You mention the (4) bias resistors, and the resistor on the quad cap, but there is not an asterisk by them. So I replace them also?
    No - You already have them there since you have the VTA driver board already installed.
    myaddiction
    myaddiction
    Post by myaddiction Fri Aug 06, 2010 8:03 am
    That's what I thought. Thanks!
      Current date/time is Fri Apr 19, 2024 9:13 am
