    bias points setup
    baddog1946
    bias points setup
    Post by baddog1946 on Thu Aug 26, 2010 6:24 pm
    Hi out there:
    I am looking for the three bias points setup that is on the amp for sale on the tubes4hifi site at the moment.
    I'm trying to get rid of the octal sockets setup
    Baddog1946.
    Re: bias points setup
    Post by Bob Latino on Fri Aug 27, 2010 5:27 am
    Hi Baddog,
    George at Vintage Electron sells these on Ebay. See the link below. He only sells a TWO bias point board and pin set for a stock ST-70 with one live and one ground point. These could be used on a VTA boarded amp, however, which needs live bias points by making both points live and using the chassis itself for a ground.
    Bias test pins with backing board
    There is one "caveat" here. If you ever decide to sell your amp in the future you will probably devalue the amp by "altering" the amp from it's original state by replacing the front tube sockets. People will always pay more for an original looking ST-70 than one whose look has been altered. Even if what you did was an improvement over the original amp potential buyers are always suspicious of modifications of the original amp and tend to pay less for a modified amp.
    front panel bias test points
    Post by tubes4hifi on Sat Aug 28, 2010 12:28 am
    if I could get about 10 people interested in something similar but set up with 2 test points
    and a ground pin I can offer these for $27 a pair including shipping,
    that's for 2 PCBs and 6 test pin jacks,
    for about the same price I can offer it with an aluminum panel that fits inside,
    see photo on my website here www.tubes4hifi.com/VTA120.htm for an example
    Post by stewdan on Thu Apr 14, 2011 8:42 pm
    Hi Roy -- Did you ever get any interest in the front panel bias test points? ( Two test point + one ground. ) Please let me know.
    Stew
    Post by tubes4hifi on Sun Apr 17, 2011 8:16 pm
    I've only sold about two of these in the past 6 or 8 years.
    Easy to make with an aluminum strip, hacksaw, file, drill, the parts are about $12, about 45 minutes of time ($30 labor),
    as always the labor cost is the major factor, that's where quantity buys reduce prices!
      Current date/time is Tue May 22, 2018 11:21 am
