    VTA PAS I/O Strip Rewire
    KCF
    VTA PAS  I/O Strip Rewire  Empty VTA PAS I/O Strip Rewire
    Post by KCF Fri Sep 03, 2010 12:10 am
    I have replaced both boards in the PAS 3 with VTA subs, and am attempting the VTA I/O strip install... It appears phono and pre outs now will ground to their respective boards. does the center of the I/O need separate grounding to chassis / elsewhere?
    Any help appreciated.
    K
    VTA PAS  I/O Strip Rewire  Empty Re: VTA PAS I/O Strip Rewire
    Post by Roy Mottram Fri Sep 03, 2010 12:37 pm
    phono ground goes to phono board only
    all other grounds are connected together by the PCB and connect ONLY to the line amp output ground, otherwise you will have ground loops and extra noise
    any further questions contact me directly
    roymottram@yahoo.com
    www.tubes4hifi.com/PAS3.htm
      Current date/time is Fri Apr 26, 2024 10:52 am
